It is currently Wed May 20, 2026 3:59 am
 Post subject: Rearend ratios .
PostPosted: Mon May 17, 2004 9:37 pm
Does any one know what rearend ratios were available on the 63 Dart with a 170 and 3spd manual trans??The rear has never been changed in this car and is a 7 1/4.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
 Post subject: 3.23....
PostPosted: Mon May 17, 2004 9:48 pm
One of the most common ratios behind the 3spd manual tranny is 3.23...some other's were offered, but at least two standard rear ratio formula's for rear ratio's are 3spd manual gets 3.23's 90% of the time, and automatic cars get 2.76's 95% of the time...
You can always jack up the rear and rotate the tire and count driveshaft revolutions/ vice-versa too...
PostPosted: Tue May 18, 2004 3:58 am
Thanks DI, I would jack it up and check myself but the car is 125 miles away from me at the moment.The reason I was asking was that with my 60 Valiant only 2 ratios were offered(3.55 and 3.21) and was wndering if more ratios had been offered by 63.
Thanks again.
HyperValiant
PostPosted: Tue May 18, 2004 4:33 am
My 65 brochure lists 2.9, 3.2, 3.5 as the only Dart gear ratios.
I'd put money on it being 3.2; never seen a 2.9 behind a 170, and usually 3.5 only behind hi-po engines (Commando).
BTW I'm trying to find someone to split a set of 4.10s with me (buy two, get good price deal)... :wink:
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Tue May 18, 2004 5:06 pm
Thanks Six,on the 4.10 gears are they for a 7 1/4 ,if so I might be interested.
HyperValiant
PostPosted: Tue May 18, 2004 5:19 pm
DB, I'd get in on the 4.10 deal if Sure Grips were readily available.
Cecil
PostPosted: Tue May 18, 2004 7:35 pm
What kind of price can we get on the 4.10's for a 7 1/4? If the price is right I would be interested.
PostPosted: Wed May 19, 2004 6:12 am
http://www.slantsix.org/forum/viewtopic.php?t=9285
Randy's sent a flyer about an "overstock clearance sale". Limited time, quantity, blather, blather.
7 1/4 4.10 new ring and pinion $126+S&H
8 1/4 3.55 " " " " $143 "
8 1/4 3.73 " " " " $189 "
8 3/4 3.73 489 case $101 "
8 3/4 3.90 489 case $101 "
8 1/4 2.56&up 27 spline 96&older Dana S/G $146+S&H
minimum order = 2 per part #
Sorry, no 7 1/4 SG units available.
I need one 4.10 set, and I can order whatever else at the same time.
These prices are probably good for wholesale customers only; I'm probably not the only one here who is. I haven't checked to see what they are retail.
O==\=/==O
- Jim Preston
PostPosted: Wed May 19, 2004 2:59 pm
Car Model: 62 Lancer GT
Do they have to be two of the same type and ratio?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Thu May 20, 2004 12:20 am
I'm interested in the 4.10 for the 7 1/4 rear. I have a couple housings, and recently picked up another suregrip unit. However, I need to wait untill after the holiday weekend, to see if the budget will allow it.
PostPosted: Fri May 21, 2004 7:20 am
JohnnyDees, as long as two of each part number are ordered, they'll be happy. If you don't need two identical sets (most of us don't), find someone who wants one and split them.
"Offer Expires 5/31/04" :(
Since I'm buying wholesale, I'll have to charge sales tax I think :x
Price starting to rise... :cry:
O==\=/==O
- Jim Preston
PostPosted: Mon May 24, 2004 2:17 pm
anyone need 8 3/4 with 3.73 ratio???
1966 Dart GT
62 Lancer GT
B Body 8 3/4
 Post subject: We'll see...
PostPosted: Tue Jun 01, 2004 10:12 am
I called to order the 7 1/4 gears, but they said they were out of the Yukon Gear sets. He offered a set from Value Gear, whom I've never heard of.
He was willing to sell one set at that price, and gave me the option of ordering more at that price if the first set is satisfactory :wink: , even after the deadline.
It came today, and they look ok, no obvious defects, only time will tell how they hold up.
Should wake up my 170 nicely! :D
O==\=/==O
- Jim Preston
