It is currently Wed Oct 14, 2026 4:42 am
PostPosted: Tue Apr 02, 2019 10:20 am
Car Model: 1964 Valiant
I've viewed Youtube videos where a headlamp is used as a test fuse for assisting in identifying shorts that result in a blown fuse. You disconnect wiring until the headlamp goes out - that identifies the wiring with the short. The headlamp draws enough current to not damage the wiring - otherwise insulation might melt. Is this method safe to use?
Tim
PostPosted: Tue Apr 02, 2019 12:33 pm
That will work. However, what if there is more then one load on that circuit. A "normal load, and the "overload". The head light would not go out, if only one circuit is disconnected at a time. What I like to do is use a auto resetting circuit breaker (they make them so they will fit in a fuse holder, or use clip leads) of about 10 amps. The breaker will keep tripping and resetting until the short is disconnected.
PostPosted: Tue Apr 02, 2019 3:02 pm
You are a smart man, Charlie. Gotta remember that breaker trick...
The headlight should dim instead of going out in the case that multiple loads are there.
