It is currently Sun May 03, 2026 6:25 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3
PostPosted: Thu May 20, 2004 1:07 pm
Thanks D, I confirmed at the Dodge dealer that the 6029060 (13/16") bolts are what I need for the 10" clutch because the 7/8" bolts are for the 9 1/4" clutch, and both these clutches and bolt sizes are listed in their parts book. The clutch article on this web site also mentions "special reduced size hex cover bolts" for the 10" clutch which I believe are one in the same bolts I have now ordered from Dodge @ $1.45/ea, not as bad as I thought. Since these are flanged I assume no lock washer required?
 Post subject: safe than sorry...
PostPosted: Thu May 20, 2004 1:17 pm
The couple of 10" clutches I've pulled from trucks had no lock washers, but I'm one for safe than sorry, when I finally upgrade to a 10" clutch I'll probably put a set on just-in-case...
cool,
