It is currently Fri Jun 19, 2026 9:17 am
Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 1 2 3 4 5 6 Next
 Post subject: Re: Jets for BBD
PostPosted: Wed Apr 10, 2019 6:06 pm
PostPosted: Wed Apr 10, 2019 6:13 pm
PostPosted: Thu Apr 11, 2019 6:25 pm
.068 .066 .065 .062 jet size were used on 1973 plastic bowl vent carbs with .062 the most common used on cars and light trucks.
PostPosted: Thu Apr 11, 2019 6:27 pm
https://quadrajetparts.com/metering-jet ... 2_149.html The jets in this link do not fit pre 1974 air bleed carbs.
PostPosted: Thu Apr 11, 2019 6:31 pm
https://www.carburetor-parts.com/Carter ... p_160.html
PostPosted: Thu Apr 11, 2019 6:34 pm
This is what the older jet looked like http://www.carburetion.com/Products/Pro ... =C2-BBD-45
PostPosted: Thu Apr 18, 2019 6:14 pm
PostPosted: Thu Apr 18, 2019 6:56 pm
That picture is a bbd air bleed carb. That brass tube with holes is main well emulsion tube. Your jets if .062 are best left alone. Carter service bulletin, number 151 May 1972 mentions wet fuel level up or down .015 and float level tolerance .030 up or down. Set to best engine operation. Check wet fuel level.
PostPosted: Thu Apr 18, 2019 7:09 pm
https://www.youtube.com/watch?v=yN1Wpm9_Xs4
PostPosted: Mon May 06, 2019 5:26 pm
PostPosted: Mon May 06, 2019 5:27 pm
PostPosted: Mon May 06, 2019 5:49 pm
Corrected info seems 1971 1972 and 1973 used same bowl vent. The 1973 had some features that were different than 71 and 72 ,but not the bowl vent.
PostPosted: Mon May 06, 2019 6:08 pm
71 or 72Image
PostPosted: Mon May 06, 2019 6:09 pm
1973Image
PostPosted: Mon May 06, 2019 6:12 pm
Internal bowl vent to top of venturi was different.
Users browsing this forum: Amazon [Bot] and 2 guests
