It is currently Mon Nov 09, 2026 7:22 am
PostPosted: Thu May 09, 2019 6:41 am
https://www.summitracing.com/parts/sum-331000/reviews/
If you have used one of these how did it work out for you? Did you run it in line with the radiator tank or stand alone?
I am considering one on my 63 Dart with 3200 converter.
PostPosted: Thu May 09, 2019 10:42 am
In GA, in the summer, with a 3200 stall, I'd consider that inadequate if you are street driving the car.
PostPosted: Thu May 09, 2019 10:52 am
I have one on my Valiant, stand alone, mounted under the passenger side floor. I am not street driving, but I have a trans gauge, and even stalling 4000+ on the line, I rarely see the trans temp over 140.
I discussed the cooler with my trans guy and he said they are excellent.
PostPosted: Thu May 09, 2019 11:08 am
That's wanted, an answer based on experience. This won't be a daily driver and with a 5 gallon fuel cell there won't be any long trips. Do you remember what brand and size you used?
PostPosted: Thu May 09, 2019 11:16 am
Mine is a Moroso. Not sure what size it is, but it's comparable to the one you have pictured.
