It is currently Wed Nov 11, 2026 12:15 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Thu May 16, 2019 8:01 pm
Valve bodies are essentially hydraulic computers, full of basic (Basic? :? ) If/Then circuits.
Just like with the silicon variety, one little glitch and it all crashes :evil:
Kudos to you for sticking with it and finding out Why instead of throwing it away.
That is when this hobby becomes a true learning experience instead of just a way to fill our time and garages.
Also, major respect to Larry and Mark at Transgo - well done, gentlemen 8)
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Fri May 17, 2019 3:07 am
Was it the same issue with both valve bodies?
PostPosted: Fri May 17, 2019 3:44 am
That is amazing, Rick. Great work. Wanna build a transmission for me?? :)
PostPosted: Fri May 17, 2019 9:35 am
Car Model: Toad Wagon
Curiosity question.
Was the washer OD reasonably close to the piston OD?
In that the washer isn't centered on the piston (as the nubbin was), and if it were too small, it could impart an angled loading when impacted. This'd result in offset wear and eventual jamming.
Edit: Stupidity answer. Notice the photo, Dick. :roll:
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Fri May 17, 2019 9:37 am
No, the reason the known good one did not work was because the Stage 3 kit blocks off the governor pressure port in the transmission case. So that one could not work because of that plug no allowing the correct pressure to get back to the valve body.
Lou, Not this week! :D :D
PostPosted: Fri May 17, 2019 9:40 am
I use one slightly smaller than the OD of the plug. That way it sat flat on the plug and was too large to get behind that little nub no matter how it moved.
PostPosted: Fri May 17, 2019 7:51 pm
Thank you. I finally got smart enough to actually look at the picture as well. :oops:
Another curiosity question. How far does that piston actually move in use?
I'm putting a 904 into Cassi, and know very little of slush pumps. Time to start learning.
Dick, 225% crazy.
PostPosted: Sat May 18, 2019 3:59 am
Don't quote me but I think about 3/8"
