It is currently Mon Nov 16, 2026 4:21 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Sun May 19, 2019 7:37 am
Had a similar issue with a Holley 2280. Removed the idle mixture screws, sprayed carb cleaner through the holes, re-installed screws. Start engine, spray carb cleaner down throttle body, then hold hand over top of throttle body until motor almost stalls, then remove hand and repeat. I guess it unplugged a blockage because now my 2280 is back to running great.
