It is currently Sat May 02, 2026 1:47 pm
PostPosted: Fri Jun 14, 2019 4:20 pm
Manual brake master cylinders use a rubber grommet on the pushrod to lock it into the master cyl. Does anyone have a source for these? At one time they came with the master cyl, but not for awhile. I did have some at one time but can't find them, and don't remember where I bought them. Can anyone help?
PostPosted: Fri Jun 14, 2019 5:47 pm
https://www.manciniracing.com/brpubu.html is this it?
PostPosted: Fri Jun 14, 2019 5:55 pm
https://www.ebay.com/itm/Mopar-Manual-B ... 1059!US!-1 doctor differential
PostPosted: Fri Jun 14, 2019 6:46 pm
Thank you.
PostPosted: Sat Jun 22, 2019 3:51 am
Got mine from Dr Diff. Reasonable price and fast shipping. Ordered on Sat, had them on Tue. Just ordered some more for Steve on on Fri, and USPS tracking says I will have them on Monday.
Call and order directly, and save some money when buying more then one.
https://www.doctordiff.com/
PostPosted: Mon Jun 24, 2019 10:07 am
Dr. Diff is good people. I've e-mailed him at 11pm and had an answer by midnight.
PostPosted: Mon Jul 01, 2019 5:54 am
I know that this is probably not a kosher way to fixvthis part but i have in the past in a pinch msde one of those parts with some old fuel hose cut and ground down to the correct dimensions.
Worked for me.
PostPosted: Mon Jul 01, 2019 6:08 am
Worked for me.
I've done that, also, when they just were not available. Then they started coming with the masters. Now they are not. but looks like there are sources, now.
PostPosted: Mon Jul 01, 2019 12:08 pm
Cool.
PostPosted: Fri Jul 05, 2019 10:24 am
Worked for me. More than once.
PostPosted: Fri Jul 05, 2019 5:40 pm
Mike was nice enough to use the lock grommet and put an L stop bracket on the pedal mount so the pushrod can't fall out even if it gets loose.
