It is currently Thu Feb 27, 2025 11:15 am
 Post subject: Compression help
PostPosted: Mon Jul 01, 2019 6:49 pm
Car Model: 1971 Dodge Dart 225 slant 6
Hey guys and gals me again needing help with compression I want to be around 10:1 to 11:1 and i have the block bored 65 over for Chrysler 2.2 pistons im using the stock 1971 225 short rods and my cylinder head cc is 58 and the head nor block has been shaved please help
 Post subject: Re: Compression help
PostPosted: Mon Jul 01, 2019 7:00 pm
You can't use stock 225 rods with 2.2 pistons. You'll end up with about 6:1 compression. You need the 7" 198 ci rods.
PostPosted: Tue Jul 02, 2019 4:28 am
Car Model: '23 T-bucket
'Zilla's right. The long rod motor, using 2.2 pistons, is the 198 (7") rods, on a 225 crank, with an overbore to match the pistons.
Where did you get info to use the 225 rods with 2.2 pistons?
Roger
PostPosted: Tue Jul 02, 2019 11:24 am
Ditto what they said. Using flat-top 2.2 pistons on 198 rods, your pistons should end up around 0.020" below the deck surface on an uncut block. Using the other numbers you provided and 0.040" for compressed head gasket thickness in this SCR calculator, that would get you right around 10.5 SCR. (If you're using dished turbo pistons, that adds ~15cc to the chamber and brings you down to ~8.7 SCR).
With the 225 rods, the pistons will be more like 0.320" down the hole, giving you an unworkable 6.6 SCR even with flat-top pistons.
Escape Velocity Racing
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 21 guests
