It is currently Mon May 18, 2026 10:04 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Wed Jul 10, 2019 10:12 am
Car Model: 1980 Chrysler lebaron 3.7l 225ci
Choke works
PostPosted: Wed Jul 10, 2019 10:14 am
On the ignition coil where is the condenser wire supposed to be
PostPosted: Wed Jul 10, 2019 11:08 am
The little capacitor that is mounted on the coil is not the condenser. It is the noise suppressor for the AM radio. Leave it disconnected for now. I THINK it attaches to the - terminal , but if you connect it to the wrong terminal you can ground the coil and not have spark. Just leave it detached.
PostPosted: Thu Jul 11, 2019 8:29 am
So today I'm getting the bolt for the harmonic balancer but idk if it the right thread that I found on a forum. It was 3/4-16,2"1/4 long
PostPosted: Thu Jul 11, 2019 9:15 am
Which size is better 2 or 2 1/2 long cause that all the hardware store has? I want a bolt cause its way easier than bumping it.
Parts store has 3/4-16,2 and 3/4-16,2 1/2
But they have the washer 2" any ideas
PostPosted: Thu Jul 11, 2019 9:59 am
Go for the 2 inch. An extra 1/2 inch might not fit and it won't give you any benefit over the 2 inch.
PostPosted: Thu Jul 11, 2019 10:04 am
So 2in long and what about the washer?
PostPosted: Thu Jul 11, 2019 10:47 am
A thick washer should be used to sprea the load of the bolt.
PostPosted: Thu Jul 11, 2019 10:52 am
A2in washer ok or bigger
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
