It is currently Mon May 18, 2026 3:27 pm
PostPosted: Wed Jul 10, 2019 7:36 pm
I put a new flex plate on my engine I am swapping into my dart. Now I can't mount the starter that did fit with the stock flex plate. I haven't yet tried grinding on the starter housing but that might be a workable solution or a different starter perhaps. I hope someone can I.D> this mini starter as I have no idea what it is supposed to fit. It was installed on a car I bought some time back. Here are some pics. Any help is appreciated.
[https://i.postimg.cc/W1NnrCSc/IMG-20190710-210341630.jpg][/img]
What do you think guys? Do I have the wrong flex plate or is there a better starter to use?
PostPosted: Wed Jul 10, 2019 7:54 pm
I took a stock starter off the shelf and it bolted right up so it's just the nose of the mini starter needs some modding. I'd still like to know what that mini starter is from if anyone can ID it.
Problem solved.
PostPosted: Thu Jul 11, 2019 12:48 pm
It looks like the one I took off a 2000 Dakota, small V8 auto trans. The engine was one of the small metric motors from the doomed Daimler merger. Over head cams, not an LA style motor.
PostPosted: Wed Jul 24, 2019 12:24 pm
That would likely be the oh-so-lovely "Power Tech" 4.7L V8...
~THOR~
PostPosted: Wed Jul 24, 2019 12:46 pm
Good to know. Thanks.
PostPosted: Wed Jul 24, 2019 6:20 pm
~THOR~
Gas Sucking Pig!
PostPosted: Thu Jul 25, 2019 11:03 am
~THOR~
Gas Sucking Pig!
In addition to a horrendous reputation for being a boat anchor!
~THOR~
