It is currently Fri Nov 13, 2026 1:53 pm
PostPosted: Mon Jul 15, 2019 3:10 pm
Car Model: Slant Six M37
I just picked up a take out engine for my plow truck project. The crankshaft moves about 8-10* before the distributor rotor starts to move, so I am assuming the timing great may be worn.. Any of the following manufactures preferred over the others for a stock to mild refresh?
Cloyes, Engine Tech, and Sealed Power look about the same from the pictures at Rock auto.. The Melling one looks very skimpy and I would not trust it as wall art...
PostPosted: Mon Jul 15, 2019 5:25 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 3561511658
This is a very nice set.
Hit the inside of the lower gear with a drum sander or dremel as its usually a tad tight to install even with the proper installation tools.
PostPosted: Mon Jul 15, 2019 7:43 pm
Good to know, I will keep an eye out for another auction to turn up....
Thank you.
