It is currently Tue Nov 10, 2026 3:09 pm
PostPosted: Mon Aug 05, 2019 11:45 am
Car Model: 1963 Dart Convertible
Year One (M&H Harnesses) shows 1964 Dart harnesses but not 63. After looking at the '63 harness it look much different than later Mopars where they broke it out into 3 separate harnesses under the hood at the bulkhead. Anyone know if the bulkhead connector is the same between '63/'64. Maybe not the pin out put will they physically plug together?
Thanks.
Jim
PostPosted: Mon Aug 05, 2019 12:19 pm
That's a good question, as my '63 sure could use some new wiring. I am surprised Dan hasn't tackled this one.
PostPosted: Fri Aug 23, 2019 9:47 am
Car Model: 1966 Dodge Dart
Got a picture of the connector? Most of the connectors Mopars used at the time are Packard 56 series.
Matt Cramer
PostPosted: Fri Aug 23, 2019 6:51 pm
Here is one on a stockish 64.
2 connectors not 3.
PostPosted: Mon Sep 09, 2019 11:31 am
In that case, I suspect they're the 56 series. Del City is a a good supplier for small quantities, if a bit on the pricey side.
https://www.delcity.net/store/Packard-5 ... ors/p_9108
Matt Cramer
