It is currently Thu Apr 30, 2026 2:29 pm
PostPosted: Mon Aug 05, 2019 9:46 pm
Hope this is the right section.
As the title says what would my requirements be for crankcase ventilation on a supercharged slant 6 ?
SC is a L67 Eaton with aa a draw through set up Weber 45 DCOE.
I will post a photo of my current PCV valve and line tonight >
I have heard about second circuits and catch cans , I am only running around 7 -8 PSI.
Cheers,
DRIVE IT,DON'T HIDE IT
PostPosted: Tue Aug 06, 2019 2:14 am
The reason i am asking these questions is my PCV Valve line connects to the SC neck/elbow just before where the SC bypass valve is .
As i don't know much about vacuum i was wondering if when the bypass valve is open which is most of the time would there be turbulence which would affect the way the PCV valve operates ?
https://live.staticflickr.com/65535/484 ... 92ce_m.jpg
https://live.staticflickr.com/65535/484 ... 74ee_m.jpg
https://live.staticflickr.com/65535/484 ... e3b3_m.jpg
https://live.staticflickr.com/65535/484 ... 250a_m.jpg
https://live.staticflickr.com/65535/484 ... 1218_m.jpg
PostPosted: Tue Aug 06, 2019 3:53 am
I don't know the answer (yet??)
Try bigger pictures so I can see what's going on.
PostPosted: Tue Aug 06, 2019 8:22 am
That should work. How are you protecting the Teflon coating on the rotors?
PostPosted: Tue Aug 06, 2019 12:50 pm
I removed the coating before i put the SC on as it was crappy .
I realise i will be loosing some PSI by doing this .
I am currently in the process of getting another set of rotors re coated by a business in Brisbane .
The coating they use can handle petrol and air .
PostPosted: Tue Aug 06, 2019 1:09 pm
Can't figure that out , Flickr is only saving them as thumbnails .
PostPosted: Wed Aug 07, 2019 1:50 am
https://www.flickr.com/photos/183261515 ... ed-public/
PostPosted: Wed Aug 07, 2019 1:55 am
