It is currently Fri May 01, 2026 4:39 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Mon Aug 05, 2019 7:17 pm
Ok reduced size of main system air bleed made carb richer and run better. I will be trying that myself. Thanks for posting your results. On the venturi screws are some stamped numbers, if still there, need good light and good mag glass to see. That can be use full info. Came in different sizes, pressed in steel bushings, some times rust away. Idle air bleed .059 .063 .067 common, idle economiser down channel restrictor .055 .059 .063 .067 .
PostPosted: Tue Aug 06, 2019 6:21 pm
Uh oh, my "6" and "8" theory has been disproven. So is it safe to say the venturi cluster with the smaller bleed holes is the six cylinder one?
No it is not, measured one carb .0472 for slant. Will check more later.
PostPosted: Tue Aug 06, 2019 6:22 pm
https://www.gfii.com/images/Greenfield_ ... alents.pdf
PostPosted: Tue Aug 06, 2019 6:26 pm
Image .0472 or 3/64 fits main air bleed on slant carb
PostPosted: Tue Aug 06, 2019 6:37 pm
venturi hole .0670 or number 51 close Imagefit, slant carb
PostPosted: Wed Aug 07, 2019 2:22 pm
So on a stock motor, which venturi set would be theoretically "better" for a slant six? Ones with smaller holes or ones with larger holes?
PostPosted: Wed Aug 07, 2019 6:54 pm
looked at couple more carbs, go with the larger ones .
PostPosted: Wed Aug 07, 2019 7:00 pm
While your at it try swapping venturi screws.
PostPosted: Wed Aug 07, 2019 8:15 pm
Hmmm. OK. I will do that.
