It is currently Fri Aug 28, 2026 10:24 am
 Post subject: Pics of My Demon
PostPosted: Thu May 27, 2004 12:09 am
Well, apparently Tripod won't let me link to my pics..so I can give a URL to visit. New to the board and having a great time!! Thanks!
http://sleddogg0.tripod.com
PostPosted: Thu May 27, 2004 1:17 pm
Nice looking car!!!
'71 Dart Swinger
PostPosted: Thu May 27, 2004 5:41 pm
Welcome to the site. The car looks great. Let us know how it is running. What kind of engine work have you done to it internally?
Joe
PostPosted: Sat May 29, 2004 4:28 pm
The motor had been built when I bought the car, it had a complete rebuild done about 3000 miles ago. It got a new crank, "perf. Cam" ( I don't know the specs, I have to do some checking), new pistons, the rods were resized, head was rebuilt with new valves ( not sure if any milling or oversized valves) all of this was on an invoice I recieved with the car, unfortunately they did not give part numbers or specify what was done as far as machine work :( All the peripherals were replaced (water pump, fuel pump etc) and it got electronic ignition. Since I have gotten the car, I have fixed the header exhaust leak, repaired the notorious fuel/temp guage problem, repaired the fuel sending unit, painted the motor and replaced the master cylinder. Right now I have the seats at the upholstery shop and am saving $$ for new carpets. I have a slight leakage at the rear of the head (gasket I am sure), I am going to try and tighten up the head bolts, but if that doesn;t work looks like the head's coming off, I will take it in and have some more work done to it then.
Jesse
