It is currently Sat Nov 14, 2026 5:59 am
PostPosted: Tue Sep 03, 2019 6:28 pm
What size o-ring does the shift cable on a 1963 A904 use?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Sat Sep 07, 2019 8:04 am
I cleaned the transmission fluid from the shift cable adjusting wheel area and the cable and tie-wrapped a paper towel around the cable.
A week later, the paper towel is still dry and the adjusting wheel and surrounding area is wet.
It is definitely the o-ring behind the adjusting wheel.
Does anyone know the part number or size o-ring that is used?
PostPosted: Tue Sep 17, 2019 2:59 pm
I don't know the size. I just bought an assortment at the auto parts store and picked one that fit.
Escape Velocity Racing
PostPosted: Sat Dec 07, 2019 11:10 am
I've had to do this a couple of times now. There are a lot of O rings that look like they would fit, only to leak like a sieve when installed.
What I ended up doing was buying a #91 O ring and wallowing out the inside just a bit with a fine sanding disk on a Dremel. Keep the Dremel moving and only take off enough rubber to make it barely small enough to slip it into the bore on the transmission case.
I have done two transmissions this way and both of them are holding so far.
1961, 1962, 2X 1963's and 1965 Valiant 200. one of the '63's has been shortened by roughly 3 feet. The `65 is a `vert.
PostPosted: Tue Jan 21, 2020 10:11 pm
Do you mean a small sanding drum?
PostPosted: Wed Jan 22, 2020 1:37 pm
I do mean a standing drum. Thanks for catching that error.
PostPosted: Sat Jan 25, 2020 8:54 pm
Thanks. I'm going to try that as soon as dry weather returns.
