It is currently Fri Nov 27, 2026 9:03 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 01, 2019 12:53 pm
Then the 210 c.i. 170 makes a lot of sense.
PostPosted: Tue Oct 01, 2019 12:55 pm
Not that I am about to set any records,
Why not?
PostPosted: Tue Oct 01, 2019 2:51 pm
The A class, 2000-2349 Lbs.
Got it! Can't wait to see it run!
PostPosted: Tue Oct 01, 2019 5:32 pm
You gonna be runnin’ gas err alky haul?
It’d be fun to get our light cars paired up along with Ryan.
PostPosted: Tue Oct 01, 2019 5:48 pm
Why not?
That's a good question...lol.
PostPosted: Tue Oct 01, 2019 6:18 pm
When I set up the original class record rules I tried to set the weight breaks to equalize things between the 170 and 225 based engines. I didn't really contemplate the 170-198 combo, which might prove to be very competitive if you could build a good one. I don't believe I ever said anything about what you could do with the crank as long as you use the original block, several racers have stroked their 225 cranks over the years. If you could build a car that weighed only 2,000# it would take about 265HP to go 11 flat in B/G. That would be 1.26 HP/Cu. In. assuming 210". To do the same thing with a 225 based motor, say 238" would take 310HP or 1.30 HP/Cu. In. It should actually be easier to produce higher HP/Cu. In. in the smaller motor. My Computech computer is dead so these numbers came from a Moroso slide rule that I don't consider to be as accurate, but I believe the relation between the two combinations is valid. Go for it!
PostPosted: Wed Oct 02, 2019 3:42 am
A lighter car with a smaller engine will always be quicker/faster if the HP/cube is the same.
Remember the formula for acceleration. If you double the weight, you must increase the power by 4 times to be equal.
That's one of the reasons why in the old days of class racing in the weight/cube classes, the heavy hitters were using "destroked" engines and light cars.
PostPosted: Wed Oct 02, 2019 6:53 am
Thanks for the numbers estimates, Seymour. I have been thinking about this for a long time (at least 15 yrs). That's how slowly I move...
1/4 mile time changes as the ratio (weight/HP) to the 1/3 power. That is what all the HP and time/ET calculators use. This is an approximation, but it works pretty well.
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
