It is currently Wed Oct 21, 2026 10:07 pm
 Post subject: The Missing Link
PostPosted: Tue Oct 08, 2019 8:36 am
Car Model: '69 Coronet, 1980 Volare Wagon
I have a Carter one-barrel carburetor with the linkage pictured here (less the spiderwebs). Sitting still, it runs beautifully on my 1969 Coronet Slant Six; however, I believe the linkage is for a car with a throttle rod and my car has a throttle cable.
Is there a known work-around that would marry these two (and the trans kickdown) that does not include finding the throttle rod setup? Or is this just a futile exercise?
Thanks in advance.
 Post subject: Re: The Missing Link
PostPosted: Tue Oct 08, 2019 9:41 am
No. This is not an appropriate carburetor for your car; you need one with the correct type of throttle lever. You'll easily find a home for a good-running carb like this what you have, though.
PostPosted: Tue Oct 08, 2019 9:48 am
What Dan said. These early rod-linkage carbs are getting harder to find, so you shouldn't have any trouble selling or trading it for a later one that's set up for a cable.
Escape Velocity Racing
PostPosted: Tue Oct 08, 2019 10:57 am
Thanks. I truly appreciate the quick replies. But, hey, at least this carb proved that the car still runs* after sitting all summer while I fixed the floorpan and the brakes! So it's got that going for it, which is nice. If anyone needs one of these carbs, let me know.
*I checked the oil level first and will change the oil before driving!
PostPosted: Sun Oct 13, 2019 7:49 am
Having proved to myself that the car runs, I rebuilt the Holley 1920 that the car came with and after a bit of tuning, all is well. But the 1920 does have an interesting feature—there’s a threaded hole in the base right next to the distributor vacuum port. What’s supposed to go there? I put a fine thread bolt in there for now but is that a long-term solution?
Thanks in advance.
PostPosted: Sun Oct 13, 2019 3:37 pm
That's for this.
PostPosted: Mon Oct 14, 2019 10:38 am
Thanks Dan; much appreciated.
You also solved my next two questions ("is that what this extra metal tube and fuzzy sleeve thing in my parts box are for?" and "what's the deal with this round thing on the exhaust manifold?")
But there's a question hiding behind those two: can an authentic-looking replacement woven sleeve be found?
PostPosted: Mon Oct 14, 2019 12:23 pm
Not only can it be found, it can be purchased.
https://www.mcmaster.com/heat-resistant-sleeves
PostPosted: Mon Oct 14, 2019 1:02 pm
Excellent; thanks!
PostPosted: Tue Oct 15, 2019 7:19 am
What's the right method for connecting the carb de-icing pipe to the manifold? It appears to be a 1/4" tube/carb fitting and a 1/4" hole on the manifold. Can I just fit 3/16" tube into the manifold?
PostPosted: Wed Oct 16, 2019 7:09 am
Car Model: 72 grumman
Hello speedbanana, I am restoring a 1972 dodge stepvan. Having some difficulty with the Carter single barrel carb on it, model 1916. I am interested in purchasing your that you mentioned at the beginning of this thread. It sounds as if you have replaced it with a Holley carb. Let me know as I'm currently looking for a carb. Is yours original? Also, what model is it?
Cheers!
Karl
Users browsing this forum: No registered users and 30 guests
