It is currently Wed Jun 24, 2026 7:49 pm
PostPosted: Mon Oct 07, 2019 2:19 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
this isn't about fit but price. Am I looking in the wrong places, or can I expect to pay over $200 for a new balancer. Also, just to make certain that I don't have more problems than I thought, today my crankshaft pulley just cut loose--spinning on the shaft. The whole assembly came off easily--no effect on the crankshaft key or anything., That is harmonic balancer, right?
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Mon Oct 07, 2019 3:03 pm
Check out
Damper Dudes
Or
Damper Dr
They will rebuild your existing damper or they have rebuilt dampers for sale.
PostPosted: Mon Oct 07, 2019 3:05 pm
Rockauto.com $137 brand new. https://www.rockauto.com/en/moreinfo.ph ... 5&jsn=1904
PostPosted: Mon Oct 07, 2019 3:43 pm
RockAuto also has the Dayco PB1001N for about the same price if you want a solid one.
They have gone up, though. I seem to recall getting one from Summit for about $65 as recently as 2014.
Escape Velocity Racing
PostPosted: Mon Oct 07, 2019 7:47 pm
Thanks for the quick responses. Got a Dayco through Ebay. Hopefully it will solve all of my problems.
Joe
Joe Hoppe
PostPosted: Tue Oct 08, 2019 5:09 am
Make sure the timing mark is in the same place as your old damper. There were several different locations for the timing mark over the years. If is not the same you will have to make a new mark on the damper.
PostPosted: Tue Oct 08, 2019 9:37 am
Thanks for the tip, Charlie. Will do.
Joe
Joe Hoppe
PostPosted: Wed Oct 09, 2019 6:38 am
Car Model: 1966 Dodge Dart
And at the $200 price point, you might as well go with a Romac 0224 - that part number is an SFI rated beast, made in Australia. Although that's mostly relevant if you're building a race motor.
Matt Cramer
PostPosted: Wed Oct 09, 2019 9:16 am
Falcon Global are getting $235 for the Romac 0224 now. And I really question whether a power steering pulley would line up.
https://www.ebay.com/itm/Romac-SFI-Stee ... SwX-pZsZLH
PostPosted: Wed Oct 09, 2019 7:19 pm
Looks like no one asked if he had the single forged crank damper with both bolt on pulleys or the factory 2 or 3 groove unicast damper...
Much cheaper to go with the Dayco decision and bolt on the power steering and AC pulley if needed anyway though....
