It is currently Mon Jun 01, 2026 1:03 pm
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 186 87 88 89 90128 Next
PostPosted: Fri Oct 18, 2019 2:15 am
Great results. Sounds like thoughtful plans, Rick. I am sure you can beat Gary's record with some focused work. I was just looking at records and thought you should be able to pop that one.
The MC will not matter too much with that light car. If you want an easy pedal, go for the 15/16". The travel will not be drastically different and you can modulate the brakes more easily. Others prefer tighter travel. I have not noticed much difference myself.
PostPosted: Fri Oct 18, 2019 3:20 pm
wow! way too go!
PostPosted: Sat Oct 19, 2019 3:40 pm
Smaller!!! Lighter!!! Faster!!! :D :D
PostPosted: Mon Oct 21, 2019 5:47 pm
Got my car on Ryan's scales tonight up in the garage. I was a little surprise that it weighed 2926# with a full tank of gas and me in the car. That's about 100# more than I thought it would weigh. 2682 without the driver.
PostPosted: Mon Oct 21, 2019 6:57 pm
A little surprising, but you do have a fair bit of street car stuff in there... Have fun with the weight reduction! 225 lbs off will get you 0.3 sec or maybe more!
PostPosted: Tue Oct 22, 2019 4:28 am
Yeah, the 3 Webers and all the external oil pump stuff added some weight too.
PostPosted: Sun Nov 03, 2019 6:06 pm
New Master cylinder installed! Lost another 2# Yippee! Couldn't bring myself to spend $40 for an aluminum adapter plate for the 4 to 2 hole adapter. So after drilling a couple holes and .....yada, yada, yada, out popped an adapter! :D :D Just need to bleed the brakes and we are ready! This also gave me a little more room between the M/C and the air inlet on the rear Webers.
Note- The Master Cylinder that I used was a Dorman #M99294 - $38
PostPosted: Mon Nov 04, 2019 6:12 am
Looks sweet! I need to do the same thing.
PostPosted: Mon Nov 04, 2019 6:17 am
Car Model: 1975 Dodge D100
Nice work, Rick!
PostPosted: Mon Nov 04, 2019 5:01 pm
How light do you want to go?
PostPosted: Tue Nov 05, 2019 3:08 am
Oh I don't know???? Maybe another 100 pound. I'm not sure I really want to do what it takes to lose a lot of weight. Eventually I will get a light weight hood and trunk lid and that would shed some pounds.
PostPosted: Tue Nov 05, 2019 11:56 am
Look at the Seymour / Ryan Car.
That's light construction there. It will give you ideas.
Those adapters are pretty simple to make, Espically if you have billets of aluminum around. If not sometimes you spend as much buying the raw material as you do just buying one.
PostPosted: Tue Nov 05, 2019 1:40 pm
Most of those ideas are not happening to my car!! :D :D
When I'm too old to race I may want it back on the street! :mrgreen:
PostPosted: Tue Nov 05, 2019 2:27 pm
Too Old to race?? What does that mean Rick. Y’all keep telling me that your never too old for such things. But I do understand whatcha talking about.Norm
PostPosted: Tue Nov 05, 2019 2:59 pm
Too Old to race??
Maybe 25-30 more years?? :lol: :lol:
