It is currently Tue Nov 17, 2026 11:54 am
 Post subject: Engine ? for D D
PostPosted: Thu Dec 05, 2019 7:55 pm
Car Model: 1964 Valiant V200 Wagon Slant Six 904
I am 68 years old and building my first slant. I have built small block Mopars since I was 16. I have a 64 V200 wagon 3,400 lbs stock eng with offy and 390 holley 904 2.9 gears. My plan is I have a 66 std block pistons .170 in hole going to port a 77 peanut head do all mods from your book. Cam choice 2106R Oregon cams Intake closes 31*ABDC will be cutting head to get 52cc chambers.Head gasket bore 3.520 compressed to .035 gives 8.403 static comp and dynamic comp of 8.03 and 161 cyl pressure. Going to use offy intake 390 holley stock ex manifold 2 1/4 ex all the way out. Want it to be a good road car with a little more snap How much timing would you think I can getaway with 30*32*34*ect. I also have a new old stock melling oil pump 7/9/90 should I use the gear on the pump or use my old one . Any suggestions would be greatly apprecited. Thank you for your time and sharing your knowledge. Wardo
 Post subject: Re: Engine ? for D D
PostPosted: Fri Dec 06, 2019 3:31 pm
... 30*32*34*etc.
Set the total advance at 30 degrees to start.
8 to 10 degrees of initial should be about right.
You may need to re-curve the distributor to get 20 degrees of mechanical advance.
It is best to use the "known" gear that has been run and show a nice wear pattern.
PostPosted: Mon Dec 09, 2019 7:50 pm
Make sure if recurving to use a new Standard Motor Product VC-239 vacuum advance can with the 8.5x stamp on the arm for
highway economy with that combination.
PostPosted: Tue Dec 10, 2019 3:19 am
Is the valiant really that heavy? I don't think it should be near that weight.
PostPosted: Wed Dec 11, 2019 6:54 pm
Rick the is a little heavy but so am I the 3400 was on a local grain elevator scale full tank gas and my 240 lbs. Take me out and gain about 2.5 seconds in the quarter Ha Ha . Good to hear from all you folks on this site all thoughts and advice appreciated. wardo
PostPosted: Thu Dec 12, 2019 3:06 am
:D :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 12 guests
