It is currently Fri Nov 13, 2026 11:50 am
PostPosted: Fri Dec 20, 2019 6:25 am
I should know this....but I don't. This bracket is for an automatic trans-to-Slant six block. Does a manual trans use a different bracket? Or the same?
PostPosted: Fri Dec 20, 2019 8:39 am
Not positive but I think they are the same.
Dave
1972 d-100 parts truck
PostPosted: Fri Dec 20, 2019 8:55 am
There is a wider one.
It has a tab for a return spring.
Manual Transmission.
PostPosted: Fri Dec 20, 2019 12:08 pm
Thanks! I recognized it the minute I saw your photo. Now I gotta go see if I can find one...
 Post subject: D
PostPosted: Fri Dec 20, 2019 4:58 pm
D
PostPosted: Fri Dec 20, 2019 5:29 pm
If you need one give me a shout, I have a few.
PostPosted: Fri Dec 20, 2019 5:53 pm
Online
They are different.
If you only had an a904 auto bracket you could cut and weld it into a manual trans bracket if you really needed to.
PostPosted: Fri Dec 20, 2019 6:13 pm
I guess I spoke out of turn. :oops: :oops: :(
Dave
PostPosted: Sat Dec 21, 2019 12:22 pm
Na, we are just a bunch of know it alls.
