It is currently Mon Nov 30, 2026 1:58 am
 Post subject: Bmw coil connect boot
PostPosted: Sat Dec 21, 2019 12:15 pm
Hi all,
As per Matt Cramer's recommendation i got a 1988 bmw to to try with my megasquirt.
It has a different boot / plug end to connect to the distributor cap.
What is this type of boot called that i need to buy for my coil wire?
It seems different than the typical usa hei/ oe stuff that I am used to.
PostPosted: Sat Dec 21, 2019 6:54 pm
I don’t know the exact boot/coil wire that you need, but I bet that a custom ignition wire source like Magnecor would.
PostPosted: Sun Dec 22, 2019 10:21 am
Thanks John. I forgot what valuable resource they have there.
PostPosted: Sun Dec 22, 2019 6:16 pm
Can you screw a spark plug nipple on it?
Then use an appropriate spark plug wire end....
