It is currently Fri Nov 13, 2026 8:00 pm
 Post subject: headers 1 5/8 tubes
PostPosted: Tue Jan 07, 2020 10:31 am
Car Model: 1969 barracuda
what I can find is only hooker and aussispeed make a big tube headers is one set any better than the other or is there more choices out there?
 Post subject: Re: headers 1 5/8 tubes
PostPosted: Tue Jan 07, 2020 10:45 am
Both seem to be good choices. I have not used either, but I like the looks (and ground clearance) of the Aussiespeeds. People have gone fast with 1.5" headers (Clifford 3X2s of all flavors, or Mopar/Hedman 6X1).
What kind of engine buildup are you doing? Drag only car, or street/strip, or...?
PostPosted: Tue Jan 07, 2020 12:40 pm
Just a FYI. Back when I was running my 65 Valiant with a 170 in "stock eliminator". Jack Clifford gave me a couple sets of headers to try. The 1.5 long tubes, with a collector extension, was better then the 1 5/8.
PostPosted: Tue Jan 07, 2020 7:40 pm
I'm pretty sure this is going to be a spray motor. 1-5/8" will probably be better.
PostPosted: Wed Jan 08, 2020 6:38 pm
Was just wondering who ran what the hookers seem to have longer tubes than the aussie
This will be sprayed heavily just dont know what would be best as far as tube length I know long tubes make good power but I couldn't find tube length on the aussie hookers are 40 inches
PostPosted: Thu Jan 09, 2020 10:20 am
Here's the set Mike had built when he was spraying. I have run them N/A. 0 torque below 4000 rpm. :mrgreen:
PostPosted: Thu Jan 09, 2020 12:19 pm
Wow those looked steped as well. ya they look like they would have no torque
PostPosted: Thu Jan 09, 2020 5:28 pm
They are stepped. The car really pulls in high gear. I went 103 with it, best with my Cliffords is 101.
Mike went 129 on the hose.
PostPosted: Fri Jan 10, 2020 4:19 am
What gears were you running and what tire size
PostPosted: Fri Jan 10, 2020 7:51 am
4.10 and a 30" tire.
With spray you don't need a lot of gear. Everybody tends to gauge nitrous by horsepower, but it really makes a lot of torque.
PostPosted: Fri Jan 10, 2020 1:30 pm
I was thinking of a 28 tall with 3:55 that maybe to weak so maybe 3:73 with a 28
PostPosted: Fri Jan 10, 2020 8:05 pm
On my old car I ran a 3.91 with an 8X26 MT ET Street. It worked very well.
