It is currently Wed Jun 24, 2026 3:08 pm
PostPosted: Fri Apr 23, 2004 10:07 am
I was reading a book today about the restoration of an old English car and it had 1 chapter in it on the overdrive unit that was in the car,....
Because I'm still in the proces of finding ways to drive at lower RPM's on the highway while keeping the close ratio (cheap!), I started thinking,...
I typen in "overdrive unit" in Ebay and I saw some comming up, one being the gear vendors unit ofcourse but the others were cheap.
I'm sure it must be able to fit these after a manual box, yank the tailpiece and make some sort of an adapterplate?? Fix the driveshaft and go!
It just sounds too good to be true,.. am I dreaming? :?: :shock: :?:
Oh please, don't wake me :P
1965 Barreiros Dodge Dart. 225 / 4 speed.
PostPosted: Fri Apr 23, 2004 10:42 am
Sounds like you found info on e.g. the Laycock de Normanville overdrive unit that was fitted to various English cars and some others as well -- they were used from the 1960s through the 1980s on Volvos, and I have one as factory installation in my '71 Volvo 164 3.3. It's a very nice unit, but it's not an add-on type of deal -- the transmission must be specifically designed and manufactured to accept it; in effect it is a part of the transmission. So, you'd be looking at adapting a non-Chrysler transmission if you wanted to use this.
The Australians have had great success putting a reportedly very strong Toyota 5-speed gearbox (from one or another type of Celica) behind the 225. There was a report on it with pictures in one of the Slant-6 News issues from the late 1980s or early '90s.
PostPosted: Fri Apr 23, 2004 11:50 am
So you reckon this can't be bolted after any other gearbox? To me these look like stand-alone units with a solenoid actuated gear in it, so if you make an adapter to put it behind, say, an A833 and get someone to change the driveshaft a bit, you'd be on your way, no?
You'd just have to flick a switch when you drive in 4th. (or 3rd.)
I mean, it kinda works like the Gearvendors unit doesn't it, the principle seems the same. I'm sure the Gearvendors unit can take more HP, but if a unit like this can take 200 HP, I would go for it
PostPosted: Fri Apr 23, 2004 11:54 am
The versions of this overdrive I'm familiar with (Yes, the solenoid-activated type) are all built onto the transmission in place of a regular tailshaft and housing -- not as stand-alone units. They may have made some of them as stand-alones, but I don't know of them.
PostPosted: Fri Jun 11, 2004 4:34 am
Back again, with an older subject,...
found this on ebay (still look for clues every know and then :wink: ), this is what the text says:
This item up for bids is a Laycock over drive, type J, serial number 27 115659 028059. This unit was removed from Volvo sedan but I cannot remember which year. I drove the car home but I cannot Guarantee that this item works. I applied battery voltage to the solenoid on the side of case and I can hear it clicking, if this means anything. The tail end spins freely. I tried to turn the speedo cable by hand but could not. The last one of these I sold was to a old guy who geared up an adapter and mounted it behind a chevrolet automatic transmission in a motor home, he called it a Gear vendor. If you have any questions please ask. Thanks for looking,,
any new views on this?
Here is the eBay link:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2481265357
PostPosted: Fri Jun 11, 2004 5:08 am
Looks like you are both right. The front of the unit is probably a direct swap for the regular V***o extension housing, therefore not designed to be a stand alone unit. However, with patience and good machining skills, you might be able to adapt it to another trans. But it wouldn't be easy, considering you have to join the shafts as well as the cases, deal with trans mounting, clearance the floorpan, etc, etc. The money you save on initial purchase would be quickly eaten up.
I think it'd be lots easier to adapt a 5 speed manual trans, there are plenty that are easy swaps and still have nice ratios.
Sorry to wake you...
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Fri Jun 11, 2004 7:04 am
Reportedly the Gear Vendors unit is actually based on the Volvo design. If you can pull an overdrive unit off the transmission it came on, with the right machine work it could be attached to a Mopar transmission. Besides Gear Vendors, I haven't heard of anyone who has actually done this. But gears are gears and there's no reason it can't be done.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Jun 11, 2004 9:25 am
That's what I was (and still am) thinking!
Finally found someone who did it!:
http://www.odspares.com/phdi/p1.nsf/sup ... ent&part=4
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 14 guests
