It is currently Sun Nov 15, 2026 11:19 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3
 Post subject: Re: oil pump removal
PostPosted: Wed Feb 26, 2020 11:44 am
Car Model: 1962 plymouth valiant
OIL PUMP IN A SLANT HUH ?
I HAVE A '72 VALIANT (My Graduation Present).
I crank 50 psi , my gear fatigues in 5 years,
and this procedure works for My 'K'.
--Jackstand front to access.
--Float Psgr Motor Mount. Jack engine to clear Pmp.
--Remove Pmp Mount bolts. Catch oil. Pull Pmp Out.
--Open gear plate/inspect/replace gear.
'Washer' Pressure Spring to 50 PSI. Moly & close.
--Reinstall Pmp with 3 gaskets.
--Drop Machine to ground.
--Change Out Idiot Light for 0-50 pressure gauge.
425806520nine
--USE FUEL INJECTION PRESSURE HOSE.
 Post subject: Re: OIL PUMP REMOVAL
PostPosted: Fri Feb 28, 2020 2:44 pm
--Change Out Idiot Light for 0-50 pressure gauge. --USE FUEL INJECTION PRESSURE HOSE.
cranksnapper
for an OIL PRESSURE GAUGE? HUH? No way.... most that I have put in take 1/8" tubing. Most come with plastic tubing. and are fastened with compression fittings. Throw away the plastic tube, go to hardware store and buy some 1/8" copper tube, substitute for plastic tube.
and add a "tee" at oil pressure port on engine, keep that original idiot light AND add the gauge as well.....
Users browsing this forum: Amazon [Bot] and 4 guests
