It is currently Tue Nov 17, 2026 12:26 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Mar 10, 2020 5:48 pm
This really oughtta be in the Transmission section, perhaps as a sticky, no?
I'll be interested to see the TSBs as listed on the table of contents page if/when you post them.
Meanwhile, '67 wasn't quite the start of part-throttle downshift on Torqueflites; that actually came as a production test run in '66 as documented here.
And speaking of TSBs:
• Governor noise on '66 904s—I had an original unrebuilt '66 904 in the '90s that worked fine but made this irritating noise.
• Increased WOT upshift speeds on 904s and 727s, early '66
• Cushioned clutch for smoother neutral-to-drive engagement on Slant-6 904s, early '66
• Always check to make sure you don't have any screws loose!
• Real cold out? Shift your Torqueflite to Neutral before starting the engine…
• …unless yours is a Torqueflite made after this round of changes, then go ahead and start in Park.
• Looks like a number of small-nose torque converters and associated transmissions escaped their Canadian cage in 1972 (assuming the smaller nose described is the same small nose as the '67-down item).
PostPosted: Tue Mar 10, 2020 6:11 pm
New 2-3 shift valveImage
PostPosted: Tue Mar 10, 2020 6:15 pm
PostPosted: Tue Mar 10, 2020 6:16 pm
PostPosted: Tue Mar 10, 2020 6:18 pm
PostPosted: Tue Mar 10, 2020 6:21 pm
PostPosted: Tue Mar 10, 2020 6:31 pm
PostPosted: Tue Mar 10, 2020 6:32 pm
PostPosted: Tue Mar 10, 2020 7:28 pm
Slant six gets limit valve Image
PostPosted: Tue Mar 10, 2020 7:33 pm
Lower shift limts Image
PostPosted: Tue Mar 10, 2020 7:48 pm
PostPosted: Tue Mar 10, 2020 7:54 pm
Hydro circuit for both six and v8 1979 fsm Image
PostPosted: Tue Mar 10, 2020 8:02 pm
PostPosted: Tue Mar 10, 2020 8:09 pm
PostPosted: Tue Mar 10, 2020 8:12 pm
Users browsing this forum: Google [Bot] and 10 guests
