It is currently Tue Nov 17, 2026 1:43 am
 Post subject: 1966 Belvedere 1 Taxi
PostPosted: Fri Mar 20, 2020 5:33 pm
Is there anything that needs to be saved from a '66 Belve I taxi cab. 3 onda tree wirg /6. 2 of them in the salvage yard. Transmission bell housing is massive. They have drool tube heads.
PostPosted: Fri Mar 20, 2020 5:52 pm
I would like to see the bellhousing with pictures.
PostPosted: Fri Mar 20, 2020 6:07 pm
me too!
PostPosted: Fri Mar 20, 2020 6:24 pm
Car Model: '23 T-bucket
Do you have key(s) for it?! If so, save the locksets as a package. Taxi and fleet vehicles were set up to use the same key (ignition) in all locks and ignition(s).
I'm with the others on the bell housing. It may be a conversion housing to use the small block 727 on the back of the slant.
Roger
PostPosted: Fri Mar 20, 2020 9:18 pm
I'll get pics tomorrow. I'll take my regular camera. I'm pulling home my '61 Plymouth 2dr HT parts car with a /6.
PostPosted: Fri Mar 20, 2020 9:22 pm
I would grab the distributors if they are original and have the little oiler cup on the side of the distributor body. Chrome trim if it is in good shape, and bits in good condition, really. Remember, those vehicles are 54 years old. Hard to find interior pieces any more.
PostPosted: Fri Mar 20, 2020 9:47 pm
Probably an 11" clutch and direct-drive starter on those cars. If so, grab the starters; people who need 'em ('60-'61 US cars, '60-'66 Canada cars, certain trucks and vans) tend to really need 'em.
What do they have on them in the way of carburetors and air cleaners?
And take lots of pics!
PostPosted: Sat Mar 21, 2020 7:41 am
While I also suspect it is the big clutch, I wonder what gearbox they used with it...? Probably the bigger V8 3 speed (A745?)
PostPosted: Sat Mar 21, 2020 10:39 am
Car Model: custom roadster
Related tangent: Brochure! (Not mine.)
https://www.ebay.com/itm/1966-Chrysler- ... 3582192258
PostPosted: Sat Mar 21, 2020 12:33 pm
Updated pics
PostPosted: Sat Mar 21, 2020 1:23 pm
Interesting replaceable element oil filter. And I see a cable throttle retrofit and a dual chamber master cylinder retrofit.
PostPosted: Sat Mar 21, 2020 2:00 pm
Do they have any HD suspension or brake parts that might fit your 61?
How about the rear axle to get away from the bolt-on flanges?
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Sat Mar 21, 2020 2:08 pm
11" clutch and direct-drive starter confirmed (and worth grabbing; don't forget the steel mount plate that goes between the starter and the bellhousing).
On a bottom-of-the-line '66 Plymouth taxicab…what chrome trim, where? :shock:
The dual master cylinder might be factory or dealer-installed equipment (see attached). The cable-type throttle is original equipment; the B- and C-body cars with Slant-6 engines got cable throttle for '62. The replaceable-elephant oil filter is a nifty piece; that was optional equipment for fleet cars. Too bad no oil-bath air cleaner (or any other kind) remaining.
PostPosted: Sat Mar 21, 2020 2:44 pm
Coolest of all...a real 'taxi yellow' car!
PostPosted: Sat Mar 21, 2020 5:55 pm
The '61 and back 3 onda tree transmissions were non-synchroed. I wonder if this 3 onda tee was synchromeshed. Would it work on a '61 with the '61 linkage??? I know this car probably has a zillion miles. Why does it have drool tubes??? I know the Alternator is probably the high end version.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 3 guests
