It is currently Mon Nov 16, 2026 12:31 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Mar 24, 2020 1:45 am
Thats what I tell my G'friend about my Flathead: Baby it just needs a jump. lol
PostPosted: Tue Mar 24, 2020 5:05 am
I am well familiar with Mark Goodman and Rusty Heisten's 62 "Team Green" Lancer. Seen it run many times and always in awe of their work and the car's performance.
Of course, any Slant 6 is super different these days, and you can easily make a bunch more power than a flathead with less work. I have 3 NA Slant engines (two running in cars, one waiting for body repair on 3rd car) that make north of 240 HP and I drive them everywhere. My turbo EFI Dart makes 350-400 HP and gets 24 MPG on 75 MPH cruising. I don't bother screwing together a Slant that makes less than 180 actual crank HP (always drag tested) these days, and that is relatively mild in my book. Just for reference...
PostPosted: Tue Mar 24, 2020 9:05 am
Car Model: Slant Six M37
I can not add a whole lot here, as I have spent more time behind a flathead than I have a slant 6. My PERCEPTION is that a slant 6 will tolerate RPM with more ease. My 230 flathead is happy and bomb proof between idle and maybe 2700RPM. Yes it can be made to turn more RPM's but a slant 6 will live and thrive where the flathead tends to run out of breath.
The 265 has a 4.766 inch stroke and is rated as 228 Lb.Ft @1600 (according to my Motor's manual)
If you are want to keep up with traffic, and drive the truck at the fast pace of today, then a slant may be happier singing along at 3500 RPM
If you are wanting to cruse and loaf, and enjoy the truck at the speeds it was built for, then a flathead will serve very well. With an overdrive, and the 265, with some modifications, it may be very nice as long as you are not trying to spin the motor real hard.
PostPosted: Tue Mar 24, 2020 11:53 am
Car Model: 1955 Dodge Truck
I will agree the Slant 6 and the Flathead 6 are 2 different animals.
I.would agree they would perform optimally at 2200 to 2700 cruising speeds all day long. Some flathead 6 owners cruise at 3000 rpm on highway.
Stock they are rated at 3600 rpm, and will perform in the 3200 rpm band if needed.
Chrysler would routinely run these engines for 50 hours at 3600 rpm for tests during the production years
You want these engines to breath snd perform better, same stuff as slant 6 in theory.
Yes a flathead can be made to rev to 5500 rpm, would they run like that all day of course not. A 225 slant 6 would perform better than L head for sustained RPM perhaps, although a 225 has a 4 1/8 stroke and is an undersquare engine, so piston speed is a concern.
Flatheads can certainly be made to perform, to the degree of a slant 6, no as they certainly are a different movie.
PostPosted: Tue Mar 24, 2020 11:55 am
thanx Lou
PostPosted: Tue Mar 24, 2020 6:04 pm
Car Model: 1964 Valiant
Yes, the stroke of the 265 is like a Cummins 6BT (4.72-inch) and the RPM it favors is similar to that widely admired diesel. George Asche says that if you pay attention to the oiling system the flathead can do sustained higher RPMs, but I don't think they make much power above 3,200 rpm. They were also used in tractors and combine harvesters. The cylinder walls tend to be thick so you could bore the 265 to 283 inches and get more torque that way. The Hudson 308 has a 4.50 inch stroke and it won some races.
These are mid 1930s technology that was an improvement over the '20s. By that time the metallurgy had advanced so that a high speed shorter four main bearing six was practical, which eliminated the need for the then very heavy seven main bearing crankshaft, and with the 23-inch flathead, it was compact enough to fit in a space not much larger than the four. The costly long bendy crankshaft is a reason Ford didn't have an inline six until 1942, why he risked building his v8. Chrysler was trying to give Plymouth buyers a six for a similar cost as a four, but he would have preferred to keep building fours for Plymouth, but in 1929 Chevy began the horsepower wars with its low cost straight six. The 23 inch six was built into the 1970s for industrial uses. The seven bearing six eventually reached 413 cubic inches and was replaced by the 354 hemi for use in heavy duty trucks .
PostPosted: Tue Mar 24, 2020 6:28 pm
Tim, yes you are correct that in stock form a 265 will make its peak HP near 3600 RPM. They will make peak torque near 1600 RPM. Of course there are variations to these curves, cam profiles, induction, compression etc.
But make no mistake they can be built to make some power well above 3200 RPM, tractor pulling is one that blasts way past 3200.
Im with you though on where do we do most of our driving, in the 2000 to 3000 RPM band. Case in point my burnt out little 228 peak torque is at 1600 rpm, but I can tell you this, it would not like to be at 1600 RPM gping down the road at 65 mph. It would be lugging and too far below its powerband.
Ive hit 4000 RPM with this engine on a few occasions, but spurts to over 3000 seem commonplace.
But my engine is old and its stock cam with .375 lit and 240 duration is not designed to spin at 5000 RPM.
Great engines and I love both Slant 6s and Flathead 6s.
They are both marvels compared to Furd flathead V8s and Chevy stovebolt 6s.
PostPosted: Tue Mar 24, 2020 6:41 pm
Brochure for truck engines
PostPosted: Tue Mar 24, 2020 8:24 pm
It is relatively easy to build a 150 hp 265, it costs a lot to build a Ford flathead 8 that makes that much and is reliable, but the classic Ford 8 sure looks cool! There are now more Mopar flatheads than Olds, Studebaker, or Pontiac etc. But the new aftermarket support for the Ford never ceases to amaze me. The overheating and cracking problems of the Ford can be fixed now, if you've got money to spend that's where the L-head hobby is. I'd sure like to see more interest in new parts for the iconic slant six, but I doubt it will ever happen because the \6 was marketed as an economy engine when it was new
PostPosted: Wed Mar 25, 2020 6:34 am
Yes to each there own, Ive had Stovebolt 6s okay if you dont rev them too much, ive owned 194, 230 and 292 Chevy 6s no complaints. Fords 1 flathead V8 for very short time no issues but dog slow.
Sold 1 of my slant 6s to a young man in need, its going into a 66 Dodge Polara 2 door, he fixed this car up as a teenager, blew the engine. He sold the car, fast forward 15 years his grandfather found car and bought it back for him. It still had blown engine, so now he can put in another and get her back on road.
Yes getting 150 to 175 hp is not a problem on a 265. Going over 200 hp will cost you...lol
Another friend shared this, buddy bavk in 1960s had 51 Plymouth, they installed truck 265 to replace burnt out 218 cdn long block. He said it had so much torque with 3.90 gears the front was of car was raising up in take off...lol
PostPosted: Wed Mar 25, 2020 7:24 pm
Question,
Did those Chrysler flat head six’s have cast iron pistons?
And if so, is that what is still used on modern rebuilds?
Asking as I think that the IH inline six cylinder motors ( Red Diamond, Silver Diamond) had cast iron pistons,,.
But I am going on 50 year old memories,,,.
PostPosted: Wed Mar 25, 2020 7:51 pm
Question,
The pistons are aluminum but have four rings. The truck pistons have steel reinforcements to prevent the ring lands from cracking - a problem with L-heads. Its common to use modern pistons in a rebuild. I think flatheads do better with the motor oils we have today. Until after the Korean war the gasoline quality was so poor that even the new V8s didn't have compression ratio above 7:1 - until the mid 1950s. High quality gasoline had been allocated by the military. Flatheads were the right motor for the times, a more sophisticated motor didn't have many advantages. And for cars that did have more power, the roads were often a limitation. Local garages could do valve jobs and overhaul L-heads to keep older cars on the road. If you had a '39 Plymouth you could swap a '59 motor in it and go. Even in the last year of flathead production for Plymouth, two thirds of Plymouths buyers chose the flathead, like Valiant buyers would do with the slant six. In 1950 the average house size in the U.S. was about 850 square feet, it was a frugal time before easy 72-month car financing.
PostPosted: Wed May 13, 2020 4:30 pm
Had a flat head block been cast as aluminum it would have helped the exhaust valve cooling and reduced hot spots in the combustion chambers. A Ford flat head v8 has been in development for a decade by Mark Kirby, the projected price is $12,000 for the all-alloy block and heads. It is claimed to produce 300 hp and 375 foot pounds torque. That's spendy but there appears to be buyers for them. Kirby is the man who learned of improved French military Ford L-head v8s and imported them to the U.S., sold them at high prices. The alloy version looks like a Ford motor but the block is much stronger. It uses modern lifters and larger water pump and a bell housing that accepts several late model transmissions. Its reportedly been undergoing testing for several years.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 4 guests
