It is currently Fri Apr 24, 2026 10:33 pm
PostPosted: Mon May 17, 2004 10:57 am
on an A body seems to require only: drum, spindle and backing plate exchange according to my limited knowledge and a search of the messages of this Forum.
Is that correct for my '62 Valiant, using '73 ten inch drums, etc, from a Dart or Duster? I want to keep the SBP because I have new Crager SS's in the SBP. Thanks everyone!
Restored '62 Signet, 229 4bl, Offy intake, auto, Dual Dutra exhausts, shaved head and block, high stall converter, 1.6 roller rockers, etc.
PostPosted: Mon May 17, 2004 12:04 pm
In '73, the upper ball joint size changed. You'll need the '73 upper control arm for the new joint size.
Cecil
PostPosted: Tue Jun 15, 2004 5:28 pm
what is SBP?
PostPosted: Tue Jun 15, 2004 6:48 pm
Small Bolt Pattern, 5 on 4in
Large Bolt Pattern, 5 on 4.5in
