It is currently Wed Nov 18, 2026 10:51 am
 Post subject: '61 Dodge Seneca UPDATE
PostPosted: Wed Apr 01, 2020 7:25 pm
I RandR Plugs, cap, rotor, condensor,wires,coil and removed the 1 bbl carb. I sprayed the intake carb hole with ether and it tried to start. Yippy!!! Carb shaft is so worn and I here ya'll stories about Reman carbs so I bought a '79 Aspen today. This aspen will donate a hood and grill for my '79 Volare with 27k actual miles. However, this Aspen will donate its "Super 6" setup for this '61 Dodge. I have my fingers crossed about the carb on the Aspen. The Aspen has a 100k miles.
PostPosted: Thu Apr 02, 2020 3:47 am
Very cool - congrats!
PostPosted: Thu Apr 02, 2020 5:05 am
Nice, What door Panels are in that aspen? is it a 2 or 4 door?
PostPosted: Thu Apr 02, 2020 7:47 am
Its a 4dr Aspen
PostPosted: Thu Apr 02, 2020 10:00 am
will that car be parted?
PostPosted: Fri Apr 03, 2020 12:19 pm
That's a neat car! My grandfather had a Seneca back in the day. He drove it until the battery rusted through the tray and the suspension rotted off. A Super Six ought to put a little bit more motivation into it.
PostPosted: Fri Apr 03, 2020 4:09 pm
agree, today a '61 Seneca is a cool car,,,,
however, think for a moment, and set your self in 1961 as a new Car Salesman, with a wife, a kid, maybe a mortgage,, and you needed to sell those to get a paycheck,,
PostPosted: Fri Apr 03, 2020 6:23 pm
Any chance of finding a good original 1 bbl carb??? The tag # is 3099S
PostPosted: Sat Apr 04, 2020 10:26 am
The slant 6 was dominating the race scenes and if you anted up and checked the box you could take your share of wins at the drag strip with a cross ram and pull your car with one of the most unique wagons Dodge ever made. A good salesman can sell ice to an Eskimo.
PostPosted: Sat Apr 04, 2020 4:07 pm
I met a guy thats converting his running '61 /6 to a V-8 car. He's shipping his carb to me. Yea!!!
PostPosted: Sat Apr 11, 2020 5:53 pm
When I was a young lad my Father had a 1960 Dodge Seneca with the 225 and a three speed manual. Good car, he killed it like all the rest he had but I helped cause I was 16-17 and drove just like you would expect. Found out it would do 98 MPH. Good luck with yours . Comfortable car.
PostPosted: Mon Apr 13, 2020 2:35 pm
I pulled the rocker arm assy. and have it soaking. I found out today while scraping the pounds of mud to
find the engine and trans. and I discovered the motor had been swapped out for a rebuild in '74-'75. 10/10 with 30 over. The farmer never heard of a car wash. lol 1 rocker foot needs a little grind or are most people replacing the rocker??? The oil pump wasn't even visible. Should I remove and clean it or just take out the relief valve??? Which hole should I force air through to clean valve trane oil passages in the head???
PostPosted: Mon Apr 13, 2020 3:54 pm
i'm just trying to get it up and running and its uglier than any old Corona. In fact,it just might scare the Corona to death.
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
