It is currently Wed Nov 18, 2026 2:58 am
 Post subject: Compression Ratio ?
PostPosted: Fri Apr 10, 2020 12:46 pm
Trying to compute my compression Ratio.
Block
.06 over
.198 in the hole
.040 thick Felpro Headgasket.
Head 44 CC'S
Any other info needed ?
 Post subject: Re: Compression Ratio ?
PostPosted: Fri Apr 10, 2020 2:53 pm
If there's any dish or valve cutouts in the piston top you need to CC them.
Don't forget to calculate the volume between the piston crown and cylinder above the top ring.
--> The Diesel Corvette <--
PostPosted: Fri Apr 10, 2020 2:57 pm
I get a compression ratio of 8.88 using the Wallace Racing site.
http://wallaceracing.com/cr_test2.php
PostPosted: Sat Apr 11, 2020 11:43 am
I get 8.866 on the UEM (Silvolite) calculator.
7.983 Effective Compression if the intake valve closes at 46 ABDC.(a "small" cam)
