It is currently Mon Jun 15, 2026 3:03 am
 Post subject: Carb Adjustments
PostPosted: Wed Jun 16, 2004 11:17 am
does turning the idle adjustment screws in lean out or richen the mixture?
PostPosted: Wed Jun 16, 2004 11:48 am
In cuts down the flow-leaner.
PostPosted: Wed Jun 16, 2004 9:56 pm
Clockwise (in) for leaner.
Set you idle to 600 rpm then back-out the idle mixture scew (counter-clockwise) to see if the idle speeds-up / smooths-out.
If the idle does not change, slowly turn the screw in (clockwise) until you hear the idle speed drop, find that point then back-off 1/2 to 1 full turn.
Users browsing this forum: Google [Bot] and 9 guests
