It is currently Fri Nov 06, 2026 7:12 am
Post new topic  Reply to topic  [ 55 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Feb 18, 2020 8:43 pm
Another 1945 first hole about 12/32, no holes at bottom Image
PostPosted: Tue Feb 18, 2020 10:03 pm
This is very interesting stuff! Especially since my 76 D100 came without a catalytic converter or charcoal cannister. The charcoal cannister was optional according to the factory advertising literature I have found.
PostPosted: Wed Feb 19, 2020 7:54 am
There are light duty trucks and heavy duty trucks, the break point is GVW over 6000 lbs. Over 6000 lbs classed heavy duty. different emission standard.http://www.slantsix.org/forum/viewtopic.php?f=1&t=62251
PostPosted: Wed Feb 19, 2020 9:11 am
Very interesting. My truck is a short wheelbase with a slant six, but it is very stiffly sprung. I would be surprised if it was rated at over 6,000 GVW, but I guess it is possible.
PostPosted: Wed Feb 19, 2020 10:44 am
Starting 1977 on drivers door was a metal data plate with that info, if not there look at pillar above door latch, should be some info there. My truck stuff only cover,s 77 and 78. VIN 4th digit A -6000 or less B-6001 to 10,000 Gvw.
PostPosted: Wed Feb 19, 2020 10:58 am
Gas tank open neck no unleaded nozzle restriction ? No cat burn leaded fuel. Egr valve there or block off plate. Air cleaner heat door?
PostPosted: Wed Feb 19, 2020 11:34 am
Open neck on the fill pipe, although I swapped to a different bed with a different fill pipe. No cat. I think it DID have an EGR, but I swapped to a Super Six intake and can't recall if the original one barrel intake had the EGR provision. The head is not original so the intake might not have been original anyway. The stock air cleaner was not present when I bought it, but it doesn't have the little air heater assembly bolted to the exhaust manifold. t is a truck from sunny dry Oregon. I think it was a farm truck.
PostPosted: Thu Apr 16, 2020 7:19 pm
Pictures of sim kit for that bulletin Image
PostPosted: Thu Apr 16, 2020 7:23 pm
PostPosted: Thu Apr 16, 2020 7:24 pm
PostPosted: Thu Apr 16, 2020 7:25 pm
PostPosted: Thu Apr 16, 2020 7:49 pm
Image The float specs for 1974 might be wrong should be 3/64. All float specs were plus or minus 1/32.
PostPosted: Fri Aug 07, 2020 7:34 am
PostPosted: Fri Aug 07, 2020 10:46 am
PostPosted: Fri Aug 07, 2020 10:53 am
After that bulletin the shape of venturi changed round to D shape,green dots, The pictures in the 77 fsm also changed. The wings also in venturi also some difference,s red dots
