It is currently Fri Jun 12, 2026 6:48 am
 Post subject: Cylinder Hone
PostPosted: Wed Apr 22, 2020 10:31 pm
I have a engine that the cylinders need a light cleaning
and the cross hatch reestablished. The bore is straight and true I checked it with a bore gage it's also has a .060 overbore. I would like to buy a flexhone.
What Grit and size should I get ?
 Post subject: Re: Cylinder Hone
PostPosted: Thu Apr 23, 2020 8:02 am
I went with a 3.5", 240 grit but I haven't used it yet.
PostPosted: Thu Apr 23, 2020 10:51 am
The grit depends upon the rings you plan to use. Plain cast rings use a slightly rougher finish than moly. I don't expect you'll use chrome. Also, be sure to read the hone instructions and watch some of the Brush Research videos.
PostPosted: Fri Apr 24, 2020 5:46 pm
I plan on using just plain old cast .060 Rings.
PostPosted: Fri Apr 24, 2020 6:25 pm
A fine choice. And congratulations on putting the overbore decimal in the proper place!
Here's the video showing the proper use of the Flex-Hone: https://youtu.be/jgDUzOxg2MU
Users browsing this forum: Ahrefs [Bot] and 5 guests
