It is currently Fri May 01, 2026 3:46 am
 Post subject: high line pressure
PostPosted: Fri Jun 11, 2004 10:20 pm
I know that driving with low line pressure can kill a tranny. What happens if my kickdown rod is too long and the line pressure is too high? it shifts firmly, near violently (i don't complain) :) and when I push the brakes near a stop lite it downshifts to 2nd then to 1st noticeably. Is the closest to a manual tranny I ever drove. I'm asking just because I replaced the ex system and had to readapt the linkage. I'll appreciate the advice. The tranny is a freshly rebuilt 904 with 1200 miles on it.
PostPosted: Fri Jun 18, 2004 12:06 pm
The biggest problem is usually a super harsh shift into reverse.
Reverse gets the most line pressure to begain with so even more can result in a broken reverse band.
PostPosted: Fri Jun 18, 2004 12:34 pm
It would pay to fiddle with the linkage some more until it's right.
Is the rod too long or just staying back (hitting something)?
If it's too long, it could keep you from getting full throttle!
Or, if it's sticking on something, someday hang the throttle open :shock: .
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Fri Jun 18, 2004 6:14 pm
It was too long. I shortened and now it's fine. Thanks for your answer. Juan.
