It is currently Fri Apr 24, 2026 9:10 pm
PostPosted: Fri Jun 18, 2004 2:25 am
Let me hope I'm not too confusing.... :roll:
If I had a power disc brake set-up on a car, could I remove the power brake master cylinder and booster and swap on a manual brake master cylinder and not experience any problems? Are the proportioning valves different between manual disc and power disc brakes?
Anyone? :)
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Fri Jun 18, 2004 7:17 pm
Not only are the proportioning valves the same, I think some years the master cylinders are the same too. The lines may be a little different though.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
