It is currently Sun Jun 21, 2026 1:38 pm
Post new topic  Reply to topic  [ 585 posts ]  Go to page Previous 112 13 14 15 1639 Next
PostPosted: Fri Jun 05, 2020 2:11 pm
Is that a front or rear setup?
Rear setup... on the 5/30/20 post.
Front setup on the 6/5/20 post.
PostPosted: Sat Jun 06, 2020 6:54 am
Cool. Let me know the total wt of those brake parts when you get a chance.
Total weight of one side including hubs, rotor, pads, caliper adapter, bearings, hose and hardware was 33.4# on my bathroom scale. I am not sure how accurate it is but that's what it says.
PostPosted: Sat Jun 06, 2020 4:06 pm
Cool. I assume that's with caliper too.
PostPosted: Sat Jun 06, 2020 4:19 pm
Yep that includes 6 piston caliper
 Post subject: 6/6/20
PostPosted: Sat Jun 06, 2020 4:32 pm
Got it somewhat together..
Upper x member is done.
Tacked some sheetmetal in the tunnel. Painted underneath.
Filled the trans with fluid.
Drove from the garage to home.
Everything works 'cept Speedo.. that will get figured out later.
Makin progress!
PostPosted: Sun Jun 07, 2020 2:43 am
Big congrats on the first drive!
PostPosted: Sun Jun 07, 2020 4:44 am
X2!! Yep that has got to feel good! You have done a lot of work in a short amount of time!
PostPosted: Sun Jun 07, 2020 5:19 am
After getting the clutch adjusted, I went on a 25 mile loop.
Everything was good, Trans is a bit noisy but I suppose thats typical from an unknown mileage essentially junkyard T5. I can get a rebuild kit for it later or get a z spec trans at some point.
Also have a few holes in the floor at this point and no interior so that can allow some noise in too. That aluminum flywheel is sweet and it seems that Falcon did a great job on the clutch and pressure plate.
PostPosted: Sun Jun 07, 2020 7:18 am
Awesome progress. I drove a 74 Road Runner big block, sans interior. It does make a big difference with the noise level.
You are going from a sweet ride to a really sweet ride......
 Post subject: 6/7/20
PostPosted: Sun Jun 07, 2020 1:20 pm
Thanks for the encouraging Words Guys. There's much more on the to do list but it's fun to be able to see measurable progress..
Next on the List.
- Finish the Floor / Get a presentable Shifter Boot, Cut a Hole in the carpet.
- Change the Rear Gear Chunk to the 3.91 Trutrac Unit - While I have the Axles out and the Drum Brakes mostly removed It would be a fine time to put the Rear Disc Setup on.
- Install 13" Front Baer Brakes.
- Relocate Battery to Trunk
- Prep and Install lighweight Hood
- I am sure there's more but I cant think of it all right now.
Pics from some of the work that was done:
I finalized the clutch Linkage setup... This involved making sure the Z bar Mount placed the Z bar in the correct plane.. So I had to reclock the Ball stud that mounts onto the Bell housing to accomplish this.
Here is a shot of the Additional material I added to get the Ball stud studly and sturdy.
Here is the The New Driveshaft. Uses a 28 Spline 1310 Slip yoke and 1310 x 1310 U Joint up front and a 1310 x 7260 (small Mopar 2 1/8") Yoke Flange on the rear Axle.
Recycled Bits of Upper X Member Going In a Bit Higher now...
Had Some 1/8" Plate lying around that i cut up to fill the ~2.5" Space.
I have some more pattern Making to do to fill in the gaps.
The Cell Buckle on the steering wheel functions as my speedometer for now. I put the phone in there with the Speedometer app, until I can get something more real worked out.
Till Next Time,
PostPosted: Mon Jun 08, 2020 11:20 am
Excellent. I think you have your trans tail a bit higher than mine. What down angle did you get for engine/trans centerline?
PostPosted: Mon Jun 08, 2020 12:01 pm
I think it's only a degree or 2.
I would actually have to double check.
PostPosted: Mon Jun 08, 2020 1:46 pm
Stock is around 2.5 deg, IIRC.
PostPosted: Mon Jun 08, 2020 2:02 pm
I took a lot of time getting stuff like that worked out.
Its super nice to do stuff like that with a 2 post and trans Jack. I don't think I would have the patience or determination to do all of that on Jack stands and creeper now.
PostPosted: Mon Jun 08, 2020 6:32 pm
Yep, I did it on my back. Lift really makes it way easier...
