It is currently Mon Nov 16, 2026 1:21 am
 Post subject: Using a lot of oil
PostPosted: Tue Jun 23, 2020 4:11 am
Car Model: D150
My slant is using a lot of oil. 99k miles on the clock and owned since new 1983. What would you suggest I tackle first?
 Post subject: Re: Using a lot of oil
PostPosted: Tue Jun 23, 2020 4:22 am
Compression and a leakdown test to determine the condition of the engine also inspect for oil leaks.
63 Plymouth Valiant Wagon
PostPosted: Tue Jun 23, 2020 5:52 am
What is a lot of oil? 1qt in 1,000 miles, 1 qt in 500 miles? Do you see oil on the outside of the engine? Do you see smoke? When? Where? Need more info. Compression test is a good start. Also service PCV system. Then go from there.
PostPosted: Tue Jun 23, 2020 12:45 pm
My guess/bet would be that he needs to replace the valve guide seals to kill the oil consumption, maybe a couple of gaskets along the way too. That can all be done in the chassis without pulling the head.
PostPosted: Wed Jun 24, 2020 3:28 am
Car Model: D150
Thank you for your time in this matter!
PostPosted: Wed Jun 24, 2020 3:51 am
How much oil?
PostPosted: Wed Jun 24, 2020 5:34 am
My engine uses 5 quarts of oil every 3,000 miles, plus a filter.
PostPosted: Wed Jun 24, 2020 10:09 am
Car Model: Dodge Dart
99k is getting close to timing chain time...
PostPosted: Wed Jun 24, 2020 11:22 am
Timing chain has nothing to do with burning oil
Users browsing this forum: Amazon [Bot] and 4 guests
