It is currently Mon Nov 09, 2026 7:13 pm
PostPosted: Tue Jul 14, 2020 2:39 am
Car Model: 1974 Dart Swinger 225
I was browsing RockAuto and came across this WVE 1A4142 "Ignition Conversion Kit." Does anyone know what it is/does? It's listed for 1973-1981 Mopars with factory electronic ignition. Here's the item description:
Ignition Conversion Kit Features:
Converts old-fashioned point/condenser or primitive electronic ignition systems to the latest solid-state technology
Automatically adapts spark timing to engine load, plug resistance and outside temperature
Delivers reliable starts and consistent ignition timing for optimal performance and gas mileage, mile after mile
Designed specifically for each application (not a "one size fits all" kit; no "tuning" required)
Eliminates periodic maintenance of mechanical contacts and replacement of failure-prone control boxes
All components fit inside original distributor cap -- no wires or fender-mounted boxes to clutter the engine compartment
Instructions included for easy installation
Alternate/OEM Part Number(s): ICC159
PostPosted: Tue Jul 14, 2020 8:57 am
https://www.rockauto.com/en/moreinfo.php?pk=3448599
Looks like a Pertronix Ignitor to me and those are less reliable than the OE electronic ignition and the HEI retrofit.
PostPosted: Tue Jul 14, 2020 6:43 pm
Say it again: HEI upgrade.
PostPosted: Wed Jul 15, 2020 5:28 am
I was researching the HEI upgrade when I came across that kit. I would like to add HEI without adding a mess of ugly gizmos and wires to my fender, so I was looking for something a bit sleeker that would do the same thing.
PostPosted: Wed Jul 15, 2020 6:41 am
Personally, I like the pertronix kit and have not had trouble with the one I have. It seems I read often about HEI module failures, so I do not see it as being more reliable, although I have no statistics to back it up. You could put a pertronix kit in your dist and keep another points dist in the trunk if you are worried? I have many of those and could send you a spare.
PostPosted: Wed Jul 15, 2020 7:14 am
Is that a chinese clone of a pertronix?
And like Dart270, I haven't had any problems with mine either. (points in trunk.....)
I use a 3 ohm coil, and no ballast resistor.
PostPosted: Wed Jul 15, 2020 7:23 am
It's not Chinese. WVE is headquartered in Wisconsin and the part says Made in USA on it.
 Post subject: D
PostPosted: Wed Jul 15, 2020 6:45 pm
D
PostPosted: Wed Jul 15, 2020 6:50 pm
Note that the spark from my Pertronix is good enough to make 250 HP naturally aspirated and pull strong past 6000 RPM in Project V...
PostPosted: Thu Jul 16, 2020 1:41 pm
There are lots of ignition systems available, but HEI is enough better than most of them to be worth going for. If you don't like gizmos and wires, you're going to have something of a list of problems to deal with:
• Existing electronic ignition box (removed with HEI)
• Existing ballast resister (removed with HEI)
• Existing voltage regulator
• Existing wiper motor
• Existing bulkhead disconnect
• Existing windshield washer tank and pump
• Existing starter relay
• Existing all the other gizmoes and wires :mrgreen:
You could empty out a Mopar electronic ignition box and hide the HEI module in it; that's a thing that's been done, but you'd still want the module over by the distributor, not in the opposite corner of the engine bay.
Poor-quality off-brand modules tend to fail early and often. So do modules of any brand that aren't mounted with proper heat sinking, or that are underfed because no relay. Good quality modules installed and wired up correctly don't tend to fail.
PostPosted: Thu Jul 16, 2020 1:51 pm
Good point, that there is some ugly junk lost with the conversion as well as gained.
