It is currently Sun Nov 08, 2026 12:27 am
PostPosted: Thu Aug 13, 2020 6:37 am
is there a source for the Idle Stop Solenoids that were used on the 78ish-88ish BBD Super Sixes and 318's With A/C?... THe little doohickey that kicked the idle up ~200 RPM when the A/C compressor was running.
It seems I cannot locate a good part # for them.. but might Have to use something listed for a GM car.... there are listings for those.
PostPosted: Thu Aug 13, 2020 2:00 pm
PostPosted: Thu Aug 13, 2020 2:07 pm
Blue dot bracket, yellow dot different throttle to match solenoid,carter part number 213-166A 1979 slant six with ac
PostPosted: Thu Aug 13, 2020 2:09 pm
https://www.ebay.com/itm/NOS-CARBURETOR ... SwC8ZcpN38
PostPosted: Thu Aug 13, 2020 2:19 pm
https://www.ebay.com/itm/318-360-CARTER ... 3307241415 Bracket and solenoid
PostPosted: Thu Aug 13, 2020 2:59 pm
Thanks Mavtv..
PostPosted: Fri Aug 14, 2020 10:35 am
I've thrown away a few of them over the years
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 1 guest
