It is currently Sun Nov 29, 2026 1:11 am
PostPosted: Sun Jun 27, 2004 11:17 am
Car Model: 1967 Dodge Dart GT
hi, trying to take the gauge cluster out of my 67 dart gt, i disconnected the two wires on the left side, the brake light, and the speedometer cable,still wont come out, when i took the cluster out of my 74 it just rolled out once i took that stuff loose, also, i already dropped the column to no avail...thanks
 Post subject: Did you get?
PostPosted: Sun Jun 27, 2004 12:09 pm
You removed the headlight harness and/or switch? How about the wiper switch/harness?
PostPosted: Sun Jun 27, 2004 12:12 pm
on this car they are in the metal dash metal the gauge cluster....
do i need to take them out still?
PostPosted: Sun Jun 27, 2004 12:24 pm
oops, thats supposed to be in the metal dash below the gauge cluster
PostPosted: Sun Jun 27, 2004 1:27 pm
looks like the box the speedo cable goes to is whats cathing, short of disc grinder, what ideas does anyone have?thanks
 Post subject: Be very Patient
PostPosted: Sun Jun 27, 2004 7:16 pm
The instrument cluster has a dropped section at its center bottom point. But, there is also a an issue of making sure you dont "HOOK" the dash harness on the back of the speedo as you pull down.
Just today, Ive dropped the third such animal. Be very Patient, there are about nine screws at the rear perimeter of the cluster. These must be removed, PRIOR to removing the instruments. The trim fascia that you see when the unit is installed should/must be removed first.
Once those screws are removed , from the back, you will see why it doesn't come out. The cluster has a section approx. 1 to 1.5 inches below the opening of the metal dash.
YES, YES, I know there are those that will pry till there eyes pop out to get the unit out. The chance of breaking pieces is probably exponential (really big).
Take the time, remove those screws first, pay attention to the details and you will see why it's worth the effort.
I'm glad I have an entire cluster housing, etc. as a spare. Hmmm, I wonder what that's worth?
IS 40:31 gets me through lifes challenges.
PostPosted: Sun Jun 27, 2004 8:58 pm
thanks so much, i didnt see how that dropped area could come out, i guess i definately will trade those parts with you! lol...check your pm box...
PostPosted: Sun Jul 11, 2004 11:30 am
okay, i see the screws but i can only get one out, now what?
