It is currently Mon Nov 09, 2026 12:16 pm
PostPosted: Fri Aug 28, 2020 12:53 pm
Car Model: 1964 Dart 270
My wiring at the switch end has frayed enough I had to take it off. While trying to get the wire out I mangled the spade a bit. All the similar sized spades from hardware stores I have tried do not fit. Is this a special connector or just a matter of tooling changes on new spades make them not fit?
I'll cobble something together that works but just curious if there is a correct part I can order somewhere.
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
PostPosted: Fri Aug 28, 2020 1:48 pm
I have always just used a regular female spade terminal that I crimped/stretched to get a snug fit on the sending unit.
PostPosted: Fri Aug 28, 2020 6:58 pm
Thanks for the info. I'll just bend and crimp one till I get it to work.
Brandon
PostPosted: Thu Oct 08, 2020 1:21 pm
I think this housing will work on oil pressure switch.
This is the female terminal that fits the above plastic housing:
You can find the brass female terminal at any auto parts store.
PostPosted: Thu Oct 08, 2020 3:11 pm
I bought a few of these:
Oil Switch Connector
They fit perfectly.
