It is currently Wed Jun 03, 2026 10:43 pm
PostPosted: Mon Aug 31, 2020 3:47 pm
Car Model: 1966 Dodge Dart 170
My slant runs smooth both on cold starts and after choke releases but if I try to remove the air cleaner while it is running, it dies. All vacuum hoses are connected and in good condition, timing is set to tdc with vacuum advance plugged. New plugs, wires and air cleaner filter. Carb was rebuilt just before I bought the car. I took it off and checked the float level and it needed adjustment but that didn’t help. This is a 1966 225 with a Holley 1 barrel. Any ideas?
PostPosted: Mon Aug 31, 2020 4:10 pm
What is your vacuum reading at idle?
PostPosted: Mon Aug 31, 2020 6:25 pm
Vacuum leak somewhere
63 Plymouth Valiant Wagon
PostPosted: Thu Sep 03, 2020 2:11 pm
18 lbs steady
PostPosted: Thu Sep 03, 2020 2:12 pm
What’s your theory?
PostPosted: Thu Sep 03, 2020 2:31 pm
The engine can pull good vacuum and still be to lean to run at idle.
Is the choke vacuum pull-off leaking badly?
PCV valve stuck wide-open?
Idle circuit in the carb plugged?
Will the engine run if you partially close the choke flap, with the air cleaner off?
PostPosted: Thu Sep 03, 2020 2:55 pm
I'm thinking the air filter is excessively restrictive and is causing rich running that is compensating for another problem. When you remove the restriction you uncover the preexisting problem.
PostPosted: Thu Sep 03, 2020 3:01 pm
18 lbs steady
I concur with Doctor Dodge and Joshie225. You have a carburetor calibration problem being masked by a restrictive air cleaner.
PostPosted: Thu Sep 03, 2020 3:18 pm
18 lbs steady
So let’s try it this way. No air cleaner installed, hard to start, won’t idle, will run if I hold the throttle open to a high rpm. Since I can’t find a vacuum leak, something in the carb is not functioning properly. Idle circuit feeds fuel, air comes from the bleed port But both are clear. What other air source could be plugged?
PostPosted: Thu Sep 03, 2020 3:29 pm
Checked choke pull off and it is good.
PCV is good
Since it will idle smoothly at 500 rpm with the air cleaner in place , I would guess the idle circuit is clear? Otherwise I don’t understand where the fuel is coming from to keep it running.
I don’t mean to sound “short” about it but this one has me stumped. Next step will be to shell out the money and try another rebuilt carb. I don’t know who built this one, po told me he had just had it rebuilt.
Thanks for the ideas.
PostPosted: Thu Sep 03, 2020 3:32 pm
...What other air source could be plugged?
Holley 1920... correct? (not a 1945?)
It is more likely that the fuel feed for the idle circuit is partially plugged or leaking internally.
Try removing the idle adjustment needle (screw & spring) at the base of the carb.(count the turns) then use spray carb cleaner, with the red tube, to "power spray" / back-flush that passage.
Re-install the screw and see if anything changes.
PostPosted: Thu Sep 03, 2020 3:46 pm
You can also try plugging the emulsifier air bleed to see if that changes anything.
This is the small brass port opening you see when looking down the carb.
Use a wire size that mostly fills this hole and secure the other end of the wire to be sure it does not get "sucked-in" when the engine is started.
PostPosted: Thu Sep 03, 2020 3:53 pm
Holley 1920
Thanks, already did the backflush, no change.
PostPosted: Thu Sep 03, 2020 3:56 pm
Thanks, I will try that tomorrow and reply.
PostPosted: Thu Sep 03, 2020 6:40 pm
What’s your theory?
Old mechanics trick use your hand to choke off the air going into the carb if it smooths out it has a vacuum leak the air cleaner has the same effect.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 19 guests
