It is currently Mon Nov 16, 2026 6:17 pm
PostPosted: Fri Sep 25, 2020 3:43 pm
Car Model: 1966 Dodge Dart 170
AC doesn't matter as it's driven off a different pulley. AC is an add-on to the back of the damper. Power steering is an add-on to the front of the damper and I can't see your damper in any of your photos.
File comment: See if you can get a view of the damper with this picture.
PostPosted: Fri Sep 25, 2020 5:56 pm
There are different PS pump pulley and pump mounting brackets for the AC / PS 225 SL6 vehicles.
The pulley is much "deeper" and the bracket that holds the pump, has a different mounting "off-set".
I will see if I can get you a photo...
Well, I have been giving bad advice. My mistake. :oops:
PostPosted: Fri Sep 25, 2020 6:02 pm
Hey no sweat, I once thought I knew a lot about these old cars but good folks like the ones on this website teach me something every time I get spunky.
Thanks for your efforts.
PostPosted: Sat Sep 26, 2020 4:35 am
File comment: Here is a picture of the pulley I need.
PostPosted: Sat Sep 26, 2020 11:13 am
This one has a much flatter pulley and longer pump mounting tabs on the bracket that aligns to the front pulley groove.
PostPosted: Sat Sep 26, 2020 12:00 pm
Yup, that's the key. The "with A/C" power steering pump bracket moves the pump rearward to clear the A/C bracketry, and the dished-forward pulley is used to keep the P/S belt groove aligned with the front sheave on the crank pulley.
PostPosted: Sat Sep 26, 2020 4:27 pm
Thank you, this is helpful. I think I can modify my bracket to match the one in the picture.
Thanks again!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 6 guests
