It is currently Mon Nov 09, 2026 3:14 am
PostPosted: Sat May 16, 2020 6:41 am
Online
Dear Slant 6 Sages,
I was able to buy an inexpensive but new 63 Dart/Valiant gas tank recently (AMD closeout) and am thinking about modifying it for an EFI in tank pump for the the 62 Valiant, while still keeping the car running w/original tank. I believe this 63 unit will bolt up, but am not sure. I could not find what I needed with the search function here. Will the filler pipe drop in and the contours and mount strap work?
Thanks very much for your help,
PostPosted: Sat May 16, 2020 7:34 am
Lou, what I hear is that the 63 tank will fit in, a little different but can be made to fit. If you can save your J Hook, that would be good to make the fit better on the strap. I think I saw on FABO you might have to move the frame strap location a couple of inches, and the hook hole? The sending unit is different, so you need the 63 part number. That's about the extent of my knowledge.
PostPosted: Sat May 16, 2020 7:59 am
Lou, here is the link:
https://www.forabodiesonly.com/mopar/th ... nk.428323/
Good pictures!
PostPosted: Sat May 16, 2020 12:09 pm
Online
Great info and link. Thanks, Stan! I am going to install an in-tank EFI pump. Looks pretty straightforward to get the 63 tank in there.
I may even relocate the filler neck somehow because of the bad fuel spill issue on these cars. Otherwise, maybe install a 1-way valve in the filler neck. Anyone know of a good aftermarket or factory retrofit check valve for our filler necks??
PostPosted: Sat May 16, 2020 12:59 pm
I installed a new 63 tank in my 62. It worked until it fell out, dragging behind me spilling fuel. No fire, but had to be towed home.
I got lucky. The strap indentations are mis-located for a 62 from my experience, be careful.
I converted to a FuelSafe fuel cell.
PostPosted: Sat May 16, 2020 2:47 pm
Thanks for the nudge and reminder. I want to re-install a factory gas tank in my 61 Valiant. It has an aluminum fuel cell mounted sideways currently.
PostPosted: Sat May 16, 2020 3:46 pm
Fell out!!!!!!!!!!!!!! Dang
Rob, 61 is Totally different. On my old wagon. Maybe sedan or coupe is different.
I think your fill is on the passenger side?
PostPosted: Sat May 16, 2020 6:26 pm
I’ll have to look. I never paid attention since it had the fuel cell when I bought it from Norm.
PostPosted: Thu Aug 06, 2020 7:26 pm
Car Model: 1964 Dart GT
On my 64, I cut a 1/8” curf notch in the bottom of the filler tube and about 4” from the fill end of the tube and about 1/2 way through the diameter. I then cut a 1/8 piece of aluminum which I cut into a 1/4 moon shape and JB welded in to the curf. What this does is holds the modern gas filler in place better during fueling and puts a curb in the bottom of the filler to prevent backwash. Additionally I covered the welded area with a hose and clamp in case the weld fails. It works.
PostPosted: Mon Sep 28, 2020 9:26 am
Andy, can you show some pictures of this?
Does it still slosh and spill on hard R Turns?
PostPosted: Tue Sep 29, 2020 1:58 am
Unfortunately, I no longer have the tube.
It did hold the gas filler nozzle during fill-ups so I could fill hands free. It also stopped the splash back during fill ups and hard right turns. I did get some though my cap was not a great fit.
PostPosted: Thu Oct 01, 2020 8:34 pm
When I get a chance, I will write up a How-To article. It is a simple alteration to do.
PostPosted: Fri Oct 02, 2020 2:36 am
Online
That would be lovely.
Thank you,
PostPosted: Fri Oct 02, 2020 4:31 am
Thank you,
Yes I second.
I had a more drastic alteration in mind, on deck for my 64 dart this winter, but if this works I cna give it a shot.
PostPosted: Fri Oct 02, 2020 5:06 am
Very cool! 8)
I had to Google curf notch... :lol:
Kerf.... I still don’t get it... :oops:
