It is currently Mon Nov 16, 2026 4:45 am
Post new topic  Reply to topic  [ 65 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Oct 01, 2020 7:55 am
The 79's had more emissions controls and sensors / thermostatic switches on them to control aspects of the emissions system.
I would have to consult the service manual to properly remember what all those are.
or Dan or Mavtv91 will chime in.
PostPosted: Thu Oct 01, 2020 8:29 am
PostPosted: Thu Oct 01, 2020 8:32 am
Did you get this arm, they different from one barrel to 2 barrel.
PostPosted: Thu Oct 01, 2020 9:20 am
Yellow dots D angles clocking to shaft are different Image
PostPosted: Thu Oct 01, 2020 10:07 am
PostPosted: Thu Oct 01, 2020 10:09 am
PostPosted: Thu Oct 01, 2020 10:50 am
PostPosted: Thu Oct 01, 2020 10:54 am
PostPosted: Thu Oct 01, 2020 11:20 am
PostPosted: Thu Oct 01, 2020 11:22 am
PostPosted: Thu Oct 01, 2020 11:31 am
That was an air conditioner car, mid-year running production change on the carburetor, solenoid for idle and a different throttle bracket on a carb. Any other air conditioning brackets left on that car. Throttle return spring bracket also used for air conditioning mount. Was it a sedan or wagon, carburetor tag number still there? Blew up your picture looks like you still have conventional idle screw and solenoid
PostPosted: Thu Oct 01, 2020 11:55 am
Car Model: 1974 Dart Swinger 225
Great info, I was going to ask if anyone had the 1979 manual. This is from a 4-door sedan, with A/C compressor still mounted on it until yesterday. I haven't had time to read all the manual pages you posted, but it looks like I wouldn't need that choke switch if I get one of the adjustable choke controllers Dan likes. I can take better pics this weekend when I start disassembly/cleaning. I should be able to go back next week and get whatever other parts I need.
On the kickdown linkage, I got the square piece with the set screw, but not the bracket with the D slot. That'll be on my shopping list when I go back.
There's a biggish bracket just above the EGR valve that I didn't recognize, looks like it might have been for the A/C.
PostPosted: Fri Oct 02, 2020 10:58 am
Is this the A/C bracket where the throttle return spring connects?
PostPosted: Fri Oct 02, 2020 3:30 pm
Think so yesImage
PostPosted: Fri Oct 02, 2020 3:32 pm
Image The air conditioning bracket replaces the standard bracket, now that's the later-model round compressor not the old cast-iron V2 .
Users browsing this forum: Amazon [Bot] and 6 guests
