It is currently Mon Jun 01, 2026 11:19 pm
 Post subject: 1964 Valiant Vibration
PostPosted: Tue Sep 22, 2020 6:22 pm
Car Model: 1964
I recently bought my dad a 1964 Valiant Conv. ,1966-1967 slant six engine (re-built), original push button transmission (904 I believe)
Car starts great idles fine, very little vibration if any at idle. Give it a little gas and the seat and steering wheel vibrate. engine not so much. Car vibrates hard so hard I'm afraid to drive the car -- don't wat to tear something up.
Things i found and replaced:
1. had the wrong motor mounts (engine was sitting approx. 3 inches off) replaced no change in vibration.
2. changed transmission mount no change in vibration
3. adjusted valves 10 / 20 according to the book , they were off quite a bit. motor much quitter . no change in vibration
4. tune up with quality parts. (had a new tune up when i got it but parts were cheap) plug wires keep falling out off cap. no change
I pulled the trans to check the flex plate and torque converter. Front shaft of transmission shows some scaring, torque converter button shows some wear. button measures approximately 1 1/2", crank shaft pocket seems to be slightly larger hard to tell maybe a 1/8" larger.
flex plate is bent a little. I am ordering a new torque converter and flex plate.
Am i on the right path? Is there anything else i can try?
Thanks
Kenny
PostPosted: Tue Sep 22, 2020 6:38 pm
sounds like you may have a small hub torque converter with a large hub crank You may want to measure them with a dial caliper and report back with the dimensions.
63 Plymouth Valiant Wagon
PostPosted: Tue Sep 22, 2020 7:24 pm
Sounds like a worn-out ball & trunion "U-joint" at the front of the drive shaft.
Usually the outer housing gets worn so you may need to convert it over to a newer & more common cross type U-joint with a"slider" yoke..
Most drive shaft shops can handle the job.
PostPosted: Wed Sep 23, 2020 4:56 pm
Car Model: 1964
measured converter button 1.50 to 1.52, crankshaft measured 1.54, flex plate has one tab bent.
on another note the car has a rubber stopper in the transmission tunnel above the transmission that is crushed, should i replace it?
PostPosted: Wed Sep 23, 2020 4:59 pm
Car Model: 1964
vibrations happens while the car in in park, drove it off the trailer and into garage. haven't had it on the road yet.
PostPosted: Wed Sep 23, 2020 6:04 pm
If the right side motor mount is upside down the car will vibrate a lot. I did this when installing a rebuilt engine in my '66 Dart.
PostPosted: Mon Oct 05, 2020 10:26 am
Ok I'll agree with the idea of a bad B&T joint if it does this going down the road but sitting still? Wouldn't have anything to do with it at that point
