It is currently Sun Nov 15, 2026 5:13 am
PostPosted: Fri Oct 16, 2020 11:46 am
Car Model: 1966 Dodge Dart GT
Please see attached diagram, for reference I have a 66 Dart GT 225, auto, Holley 1920. Throttle return spring is missing, anyone know a part number or size, weight, of spring?
PostPosted: Fri Oct 16, 2020 3:01 pm
Dont know but I can measure the one on my 64 and post it for ya..
Its's the stock parts there for now.
PostPosted: Sat Oct 17, 2020 8:20 pm
I bought a set of 6 assorted springs on Amazon and just messed with it till I found one that fit the needs on my Volare.
PostPosted: Fri Oct 30, 2020 7:14 am
Hi Greg, I hate to be a pain but were you able to measure your spring? Thanks.
PostPosted: Fri Oct 30, 2020 10:06 am
Ooh That car is home now.. I totally forgot about it, I will get it tonite.
PostPosted: Fri Oct 30, 2020 10:53 am
Thanks Greg, side question, what size rear wheels are they that you can tuck them into the rear wells?
PostPosted: Fri Oct 30, 2020 11:30 am
17 X 8's at +52 Offset with a 69 B body rear, I am sure with the proper "A" or "FJM" Body Rear end and proper offset you can fit 17 X 9's without cutting.... Bigger than that then you are into mini tub territory.
My + 52 MM 17X 8's ave about an inch clearance to the centerline of the car's body, but Do rub the outer wheel house in full compression.
↓↓↓↓Read about the maladies of all that here↓↓↓↓
https://www.slantsix.org/forum/viewtopi ... 6&start=60
PostPosted: Fri Oct 30, 2020 6:45 pm
upon inspection I think my spring was broke and butchered and cobbled sometime before I owned the car.. but it still works properly as is.
Image20201030_194525 by Hyperpack, on Flickr
Image20201030_194644 by Hyperpack, on Flickr
Image20201030_194520 by Hyperpack, on Flickr
Image20201030_194450 by Hyperpack, on Flickr
PostPosted: Sat Oct 31, 2020 4:12 pm
GREAT! Thank you Greg ad thanks for the wheel discussion!!!
Jay
PostPosted: Sun Nov 01, 2020 1:42 pm
Jay
No problem.. you need to stop out this way sometime and I will take ya for a ride in the dart.
Users browsing this forum: Amazon [Bot] and 6 guests
